more HID probs
more HID probs
well in my 06 ram i have another HID prob, i finally got a pro to put in my headlights and everything was fine unitll i was driving one night and turned the lights on while i was driving and my abs lights n **** came on and my lighs all went out the truck dropped to 4cyl modeand wouldnt get out and truck started shaking violently until i shut it off and restarted then it was ok, happened twice now.. any ideas?? obviously the HID's r ****ign wit the comp in some way..
RE: more HID probs
I searched your problem, here is what i came up with....
1. ReCheck your bulb fittings.
2. Check the HID box for any scratches.
3. Check the headlight relay.(it might be in there, most HIS kits are just a simple plug and play and this could be the problem)
4. what you said, "the computer", just unplug the negative battery terminal for like 10+ minutes and let it reset. Then hook it back-up... Problem should be Fixed.
