axles
Old Mar 4, 2007 | 04:31 PM
Leeiacacocca's Avatar
Leeiacacocca
Default axles
Does anyone have any info on swapping axles ratios? I have an 03 2500, hemi w/3:73 Thinking I'd like 3:92
Old Mar 4, 2007 | 05:35 PM
motorider228's Avatar
motorider228
Default RE: axles
just look on some gear website and see whatthey offer for your axles. I went from 3.55's in my 1500 to 3.92's. 3.73 to 3.92 is not a noticeable difference, why do you want to go to a lower ratio?
Old Mar 4, 2007 | 08:14 PM
Leeiacacocca
Default RE: axles
More towing, better offline snap, and I was wondering if it would keep the overdrive from "hunting" so much. I'm new to the board but I"ve had the truck since new.
Old Mar 4, 2007 | 09:04 PM
djr04's Avatar
djr04
Default RE: axles
If I were making the swap myself for those reasons, I would stick in some 4.56's. I'm pretty sure the powerwagon comes from the factory with 4.56's, so they shouldn't be too tough to find for your 2500.
Old Mar 4, 2007 | 09:48 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: axles
Powerwagon comes off the line with 4.10's.
Old Mar 4, 2007 | 10:14 PM
Dr Jeckle's Avatar
Dr Jeckle
Default RE: axles
Power wagon has 1-ton axles, and my neighbor's has 4.56's, but also, it has 33" tires. I wouldnt want 4.56s with stock tire ratio, but like said above, from 3.73 to 3.92 isnt a big enough difference to make it worth while. 4.10s, (if you can find them) would pull hard. The 2500's with the hemi does not have the same axles as the cummins, except in the power wagon, thats one of the reason it cost more. From '04, the hemi 2500s have a new American Axle just for these trucks. Its a 10 1/4 or 10 1/2 AA. Its been a day or two since I was looking into it. Randy's Ring and Pinion carries them. Good luck to you.
Old Mar 4, 2007 | 11:06 PM
2007 SLT Hemi Power's Avatar
2007 SLT Hemi Power
Default RE: axles
not worth changing a 3.73 for a 3.92
Old Mar 5, 2007 | 01:08 AM
Leeiacacocca
Default RE: axles
I appreciate the info you guys have given, I love these forums!
Old Mar 6, 2007 | 09:46 PM
mikesram's Avatar
mikesram
Default RE: axles
ORIGINAL: 2007 SLT Hemi Power
So would you say going from 3:55 to 3:73, same logic not worth doing? I was thinking of changing to the 3:73. Just want something lower.
Old Mar 6, 2007 | 09:58 PM
The_Bishop's Avatar
The_Bishop
Default RE: axles
All Power Wagons come with 33" tires and 4.56 gears.
