GOOD YEAR TIRES??????
Old Mar 29, 2007 | 01:58 PM
Denniss66's Avatar
Denniss66
Default RE: GOOD YEAR TIRES??????
i got 90,000 km out of my stock tires. the front set would of lasted alot longer but i ended up getting a nail in the side wall so i had to get new tires. i bought the front tires first then back ones after summer was over. i wish i would of knew that bfg all terrains were only 600 more cause i would of went with those instead i got michelin ltx not the greatest tire but it its better then the good years.
Old Mar 29, 2007 | 03:48 PM
stump_breaker's Avatar
stump_breaker
Had the stock Good Year Wrangler GSA's on my 05 Jeep. At about 24k miles they got to where it was taking about 4 to 5 ounces inside and outside to get them to balance and then that was no gurantee. Also, they wore quickly and I am religious about rotating and balancing every 3000-4000 miles since Kaufman county is too busy stealing my tax money to actually put it back into improving the roads. At 25k miles they were nearly to the wear bars on the tires. I recently went to 32 x 1150x 15 BF Goodrich A/T's and I will probably never go back.
I hated the stock Michelins that came with my ex-Dodge but they wore well. I got rid of the truck around 25k miles and had better than 1/2 tread left.
Old Mar 29, 2007 | 05:14 PM
Ricker's Avatar
Ricker
I'm sure you're talking of the Goodyear Wrangler's that come on the Ram's 04 and newer. I had the Goodyear LS on mine when I got it new and those tires sucked hard. No grip on dry or wet.When I switched to the General Grabber UHP (after only 29,000 miles) I thought I was in tire heaven. What a difference! You should definately go with a different tire.
Old Mar 29, 2007 | 10:00 PM
Ram_Sport's Avatar
Ram_Sport
wiiieeeerrrd, our '03 got nearly 60k outta the first set of rubbers
Old Mar 29, 2007 | 10:13 PM
Dagger213's Avatar
Dagger213
I got 54,000 out of my stock tires. I have a 04 standard cab ram with the 3.7 and 17" rims.
fronts could of gone longer but it was cheaper for me to change all four.
Old Mar 29, 2007 | 10:24 PM
Johndcjr1989's Avatar
Johndcjr1989
i believe the stock tires on the 17s are michelins. thats what my dad had on his 03 with 17s at least.
Old Mar 30, 2007 | 02:32 AM
bomech's Avatar
bomech
I had 38,000 miles on my tires with plenty more tread,when isold it to my little brother. i had the dealer rotate my tires for me, just didn't fell like doing it.
Old Mar 30, 2007 | 06:36 AM
BgBluRam's Avatar
BgBluRam
ORIGINAL: Johndcjr1989
My 03 had Michelins on the stock 17" aluminum wheels.. They lasted about 44k miles, than I got some cheap Kelly A/T tires, and only had them on for about 5k and they were already at about 40% left.. They were horrible.. The new Toyo's are going to last a while though!
Old Mar 30, 2007 | 11:19 AM
derwood's Avatar
derwood
Haven't heard anything good about these tires. I rotate mine every 5k and try to drive like an old man. Here's a link to Tire Rack about the review on the stock tires.
http://www.tirerack.com/tires/tires....gler+HP#Survey
I am looking for some 17's to run in the winter months as there is a better selection and not quite as pricey. I'll keep the 20's for summer as the chrome-clads don't like the salt too much.
Old Mar 30, 2007 | 07:58 PM
tailgatedrinkin's Avatar
tailgatedrinkin
ok so im going to go with a different kind of tire, now ive heard the horror stories that these were really expensive since there on the 20inch rim. how much ami looking at spending on a set of 4 quality new tires??
