headlamps
Old Apr 13, 2012 | 11:38 AM
numnuck's Avatar
numnuck
Angry headlamps
2 lamp system to 4 lamp system?
Old Apr 13, 2012 | 06:35 PM
dirtydog's Avatar
dirtydog
Moderate User
I suggest you take some time and explain what it is you are having problems with or what type of advice you are looking for.
A blank statement like that will get you nothing in return. It shows you didnt take the time to search or help other help you.
Welcome to DF btw.
Old Apr 14, 2012 | 02:13 AM
Mikeyyy816's Avatar
Mikeyyy816
Ummm.... Clarification please. Thanks. I think your asking if you can go from dual lights to quads... Yes you can, I did! Do some searching...
Old Apr 14, 2012 | 10:45 AM
billy.level's Avatar
billy.level
01 caravan on low beam have LT hdlmp,on hi beam have rt hdlmp pull the combo switch back and hold it , have both, have replaced both bulbs and the combo switch and all fuses and relays are good and still the same problem. please help.
Last edited by billy.level; Apr 14, 2012 at 10:50 AM. Reason: forgot the make and yr
Old Apr 14, 2012 | 06:04 PM
numnuck's Avatar
numnuck
Angry Dual to Quad lights
YES I want to go from dual to quads.Dual aftermarket HIDS only have a low beam & the state of kentucky requires high & lows.Can I splice into the dual wire to get quads or do they make a plug to seperate the wires to get quad lights.My truck is a 2010 dodge ram 1500 SLT, I'm 67 years old & it gives me something to do.Thanks for any help with this.
Don Miller
Old Apr 17, 2012 | 04:04 PM
Mikeyyy816's Avatar
Mikeyyy816
I went from duals to quads... it's completely plug and play...
My high beams are still halogens because after using the HID's on lows it's 100% pointless to use my highs. The highs are useless after using HID's.
Old Apr 17, 2012 | 06:16 PM
numnuck's Avatar
numnuck
Angry numnuck dual lamps v quades
Factory duals on my truck are furthless now and I still have to have high & lows for inspections.I am an x-body man,after adjusting lamps they still suck.i think its just a pour dezine,any way I just want a the quadlook rather than the dual.
Old Apr 17, 2012 | 07:48 PM
Mikeyyy816's Avatar
Mikeyyy816
You can go to Quads..that's no issue. Total plug and play... but when you do the swap I don't think it's possible to get the High Beams in HID's. You can have HID low beams and halogen high beams. I don't know KY inspection laws, but if both are required to work, they will still work with the Quad lights. They just both won't stay on at the same time.
