Instrument Panel Anti-Glare?
Old Apr 9, 2014 | 07:34 PM
Alfons's Avatar
Alfons
Default Instrument Panel Anti-Glare?
Driving a lot during my current move, I've noticed that with the sun low on the horizon and the angle & finish of the instrument panel cover, it's very prone to being washed out by glare. At night, I see the reflection of the instrument panel very clearly on the driver's side window. I feel that both of these conditions are a safety factor & can probably be minimized with having a mat finish on the panel cover. Does anyone know of any product or treatment that can reduce the glare/reflection?
Old Apr 11, 2014 | 09:33 PM
bluebeast1562's Avatar
bluebeast1562
Don't know of any treatment but you could try the lightest cling tint you can find at Walmart. Sound hooky but worth a try if it is as bad as you say. The good part of the cling tint is it is not permanent. Hope it helps
Old Apr 11, 2014 | 11:24 PM
dirtydog's Avatar
dirtydog
Moderate User
How is the instrument cluster being washed out a safety hazard? Maybe I'm not understanding you.
Reflection of IC in side window happens to a lot of vehicles. I would suggest using the Dimmer switch and turning the brightness down a bit. That should help.
Old Apr 15, 2014 | 11:40 PM
Mikeyyy816's Avatar
Mikeyyy816
At night time if the glare is that bad...there is a switch to the left of the steering wheel and you can dim it all the way down. I hate bright lights when driving but these stock gauges aren't all that bad at night. I have 5% limo tint on my truck and everything reflects off of it. But I'd have to agree with blue beast...go with some tint on the dash?
