2009 Crew needs new shocks, recommendations?
Old Oct 5, 2014 | 01:20 PM
co.45's Avatar
co.45
Default 2009 Crew needs new shocks, recommendations?
I am looking at replacing the shocks on my 2009 4.7 1500 crew cab and want to keep the original ride quality. I don't need to stiffen anything up. I have about 58K miles on the oem shocks. Did a few searches for shock replacement information and didn't find much so still have a few questions. How many miles have you got out of the factory shocks? Should I stay with MOPARs shocks? If aftermarket, what recommendations?
Old Oct 5, 2014 | 05:49 PM
Johnn123's Avatar
Johnn123
I hear the stockers last about 20k miles before theyre toast (heard that on another forum). At nearly 60k I bet your in dire need of shocks... I know I am and Im at 42k miles. I would not replace with the OEM's myself, id go with the Bilstein shocks for superior ride quality. You can get the fronts in an adjustable to level as well which is what im planning to do.
Old Oct 5, 2014 | 07:02 PM
Go with Monroe. Never had an issue. Ever.
Old Oct 5, 2014 | 10:24 PM
POWER SEDAN's Avatar
POWER SEDAN
Bilsteins. Ride is better then stock, many here who have them installed (as myself) will support that statement. Good possibility they will last longer then your truck.
Old Oct 6, 2014 | 07:42 AM
biggcrisp's Avatar
biggcrisp
My 2010 Crew Cab has over 123k miles with the original rear shocks and front struts showing no sign of leakage and the truck levels without bouncing after pushing down on any fender. Will they make it to 200k, possibly, who knows?
Amazon has Bilstiens for the rear at $79.00 each. If you are capable of loading the front struts yourself, you have more options.
Napa has the best deal on the (loaded) front struts in my area. There is nothing bad about OEM or Monroe, etc.
Please share your experience. Sooner or later I will change out mine too Lol.
Old Oct 10, 2014 | 04:02 PM
Tunaman's Avatar
Tunaman
40,000 miles on 2012. See absolutly no differance than when it was new. If they haven't leaked, i doubt there is any need to change them. JMO
Old Oct 10, 2014 | 08:55 PM
POWER SEDAN
My '09 Ram had the passenger side replaced at 4k, and my drivers side at 23k. Bad luck I suppose.
Old Oct 11, 2014 | 11:07 AM
Duso02's Avatar
Duso02
Really? I've never heard that. I know many change them but that is more or less because they want to not that they need to. I see no need to change mine unless they stop doing their job.
Old Oct 16, 2014 | 08:40 PM
Johnn123's Avatar
Johnn123
Just sayin what Ive heard. Some will fail before others, such is truck parts haha. Few diff forums Ive seen people NEEDING to replace, not just modding. I know mine need to be changed, you can feel it. Ive got about 42k miles (70k kms) on my 2010.
Old Oct 21, 2014 | 08:35 AM
oldjeep's Avatar
oldjeep
I got just under 100K on my stock shocks. Should have just bought another set of factory replacements, the Monroe Reflex shocks have been a disappointment.
