2010 Needs Tires
Old Dec 10, 2019 | 03:58 PM
SonofSparks's Avatar
SonofSparks
Default 2010 Needs Tires
Anyone have any experience with Goodyear Wrangler SR-A or Falken Wildpeak H/T - 275/60/20's?
I do mostly highway - occasional snow (Pennsylvania) - don't need any mudders or anything super aggressive.
Hoping to replace on a bit of a budget.
Thanks !!
Old Dec 17, 2019 | 07:05 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
my 17 came with the sr-a on it, stay far away, they wear like iron, but grip like ****, rain will feel like ice and forget about snow.
I put a set of cooper at-3s on mine last month when the sr-a finally wore out (75k miles later)
Old Dec 23, 2019 | 03:32 PM
businessteacher001's Avatar
businessteacher001
Hi, Bill.
No specific recommendations, but my experience with Discount Tire has been very positive,
and they are highly rated in Consumer Reports. When I needed tires for my Dart, they were
among the least costly and their service was excellent. I would go to them with the same questions
and see what works. My RAM also uses 20's, and I know it won't be cheap when the time comes.
Sam
Old Dec 23, 2019 | 05:11 PM
primem's Avatar
primem
goodyear wrangler duratracs...they are not cheap but they are the best truck tire imo
Old Jan 2, 2020 | 08:29 AM
gonsnow's Avatar
gonsnow
The higher the mileage rating is the worse the tire will be on snow and ice. To get high miles the rubber needs to be a harder compound. I run Cooper AT3 and drive on plenty of snow and ice here in Montana and Wyoming and they are great. The drawback is I get about 40K out of them because they are a soft compound making them great on snow and ice.
Old Jan 6, 2020 | 06:31 AM
shrpshtr325
THE ULTI-MOD
this is true to a point, but the at3s i just put on my 17 have a 65k mile treadwear warranty, unless you drive around with a trailer, you should be close to that number on life (you usually get a pro-rated warranty on the tires to that mileage if they wear out early)
the sr-a that came on my truck had a 50k mile threadwear warranty
you tell me which tire grips better (since you have driven on both).
I got 75k miles out of the SR-As to 5/32 tread hope to get the same out of the AT3s. But modern tread compounds and technology have made it possible to have a nice grippy tire which still has good treadwear.
Old Jan 8, 2020 | 09:12 AM
SonofSparks
Thanks everyone for the recommendations.
I went with the Wrangler SR-A 's - couldn't pass up the price $538 - installed out the door at Sam's Club.
Truck has 63,000 miles and this is the 3rd set of tires. Original were Goodyear HT ? that I got 38,000 out of replaced them in 2014, then went with Cooper HT+ from Tread Depot (when they were in business) which were fine for awhile. Since I hardly use the truck and it sits outside and given the age, I was losing air in each tire. I was tired of putting air in every time I went to use it. The Coopers were not all that bad, but being 6 years old and sitting for extended periods, I figured I would replace them. I plan on using the truck more this summer on some long trips.
Thanks again !
Bill
Old Jan 9, 2020 | 06:43 AM
shrpshtr325
THE ULTI-MOD
