Deleted MDS w/ new cam/lifters CEL system lean, cylinder 7 misfire
Old Dec 3, 2023 | 07:12 PM
hookinhogs's Avatar
hookinhogs
That, I am not entirely sure. I don't know if the PCM will also stop injecting fuel/firing the coils on the cylinders it thinks should be deactivated..... Likely it doesn't.... which means you will have four dead cylinders, that are still doing the compression thing. That will REALLY turn the truck into a dog.
It has a CEL so the MDS system doesn’t work. I have no fear it’ll turn on or work in that way, my fear is for some reason it changes the fuel or timing because of the lack of the MDS system and that damages my motor that way.
Old Dec 4, 2023 | 06:59 AM
I don't think that'll be an issue. If the PCM is aware that MDS isn't working properly, and disables it, (and sets a code....) likely it'll just run the motor normally.
