Why such poor tow raitings?
Old Oct 20, 2008 | 11:45 AM
  #21
HEMI_ROM's Avatar
HEMI_ROM
Originally Posted by silvermach2002
He's right you know, brand loyalty aside, the F-150 is way more truck than the new Ram, and a nice one too. Its not all about horsepower, despite what some uneducated people might think, you have to take in axle gear ratio, transmission gear ratio, toque, transmission shift points and a myriad of other things into consideration. So when it comes down to it, the mfg. engineers decided that the F-150 can pull 11,300lbs. safely and the Ram can pull 9100lbs, safely. If the situation arises, and you can't borrow your friends truck, or rent one, or buy a new one or second one, the F-150 can pull 2,200lbs safer than the ram. Its just a fact, yes the ram can pull more than 9,100lbs, but if you use that logic the F-150 can pull more than 11,300lbs. The new Ram has many nice features, and it is a great looking truck, but towing is just a little off. On the other hand the new coil rear is going to be killer off road.
He is entitled to his opinion, as you and I are ours. However opinions never make one right or wrong so you can go ahead and claim he’s right, but that still won’t make it so. Since you are educated, ostensibly, you will likely agree you have never seen a transmission or gears pull a load up a hill by themselves. Moreover, it is highly improbable you will ever see just a frame or bolts pull a load up hill ether. Call me crazy, but I think power might be important here, and the more the better. The Ram has more power – period. But wait, how can that be because the F-150 is “way more truck than the Ram” *if* we are to dismiss such a trivial thing as the engine. For those who think the F-150 is the better truck put your money where your mouth is and go buy one. I’ll be seeing you at the stoplight in my Hemi Ram.
Old Oct 20, 2008 | 12:21 PM
  #22
Cummins3500's Avatar
Cummins3500
Originally Posted by HEMI_ROM
No, having my opinion doesn’t make me wrong. It might not make you happy but it doesn’t make me wrong. My opinion is, and remains, that power is an important part of towing capacity. As far as brand loyalty yes I am brand loyal to Dodge, if you have a problem with that too bad. In case you missed it, this is a Dodge forum. If you are of the opinion the Ford is better fine by me, but if your expecting me to buy that your wasting your time. The fact is the Hemi has more HP and torque than the 5.4L. The fact is the Hemi Ram will outrun the F-150 light to light and top end every time. These are facts so if you have some evidence to the contrary present it. Or you can just sit back and keep typing I’m wrong.
Don't let me wrong,I like Dodge,they so cool,but as I see the owerall quality is poor,I mean Ford win here,or I'm wrong?Look,Ford have less HP,but more towing,its a truck,its not racing car,its truck for havy work.And again,coil rear suspension is not good idea for truck that build for towing,havy load.If I'm wrong just correct me.
Old Oct 20, 2008 | 12:24 PM
  #23
Cummins3500
Originally Posted by finc.jb
My last thought on this is this: if your going to tow very regularly your better off with a heavier duty truck, if your more in the being able to throw a bunch of crap into box and take you and a couple friends somewhere the dodge is a better suited truck.
If you like the Ford 'cause it can tow that much and like the looks, go buy one.
If you like the Ram 'cause it has a great ride and like the looks, go buy one.
No one truck can do everything perfectly.
Total agree!!!
Old Oct 20, 2008 | 01:02 PM
  #24
HEMI_ROM's Avatar
HEMI_ROM
Cummins3500. it is not my place to correct you on your opinion and I have no desire to shoot it down. What I am trying to get across is your opinion doesn’t make mine wrong. If you are all happy in the pants about the F-150 more power to you. Listen, the ľ ton 2500 Ram tows more than the F-150 does but that doesn’t make the F-150 any less of a truck - by your logic it would. Conversely, the Ram being more powerful and faster doesn’t make it any less of a truck than the F-150 ether. The previous Ram had the same towing capacity as the new one with coils. You may not think that coils are a good idea but I have yet to see any specific reason why this is so. If you have some empirical data to dispute this other than “it’s not a good idea” then I am certainly open to changing my mind. When you say a truck is not for racing then OK I accept your opinion. However, there are certainly a lot of F-150 owners out there who will not agree with you. A quick visit to a Ford truck forum will reveal no shortage of threads about how to hop up the 5.4L engine especially in regards to keeping up with the Hemi. More significantly, you will find plenty of Ford owners (not me) complaining about the lack of power in the F-150. We may just agree to just disagree on the power issue.
Old Oct 20, 2008 | 07:30 PM
  #25
TXcharger07's Avatar
TXcharger07
umm well it still has to stop.
and English fail.
Old Oct 21, 2008 | 09:08 PM
  #26
emcanurse's Avatar
emcanurse
I wonder if the OP uses a weight distributing hitch while towing. IMO the engine can certainly handle a much higher amount than what is listed by the manufacter (?sp). I have towed many many miles in a beat up old chevy van. I have even towed close to 12000lbs with it , although it sagged like a pair of old ****. I seldom see in these tow posts any mention of a weight distributing hitch at all. These are essential IMO for any tow greater than 4-5K LBS. They smooth out the ride and make it easier on the rear suspension. Remember that the RAM has a class IV hitch and they are rated for up to I believe around 14K lbs. Also the use of a trailer with electric brakes is also a must ...unless you like doing pads and rotors often. Just my 2cents
Stuart
04 RAM 1500
Old Oct 22, 2008 | 12:11 AM
  #27
TXcharger07
actually, the 09 F-150 that ford uses to tow 11,300 pounds around of there show stuff for the new truck... sags like a **** but it also has the helper bars on the hitch to kind of even it out. i thought it was pretty funny.
Old Oct 22, 2008 | 10:49 AM
  #28
emcanurse's Avatar
emcanurse
I fail to see how the "helper" bars are funny. Regardless of the tow capacity...I would use them every time I tow over 5000lbs. They are an important component to towing for any truck out there. Those "helper bars help to even out the weight distrubution front to back and help the trailer immensly to track better. As I said above the tow package includes a classIV hitch and is rated to handle ~12K lbs. I wonder if anybody else uses a weight distributor or not . Also electric trailer brakes are necessary as well not just a surge brake.
Old Oct 22, 2008 | 11:50 PM
  #29
cyclone429's Avatar
cyclone429
Fords are geared for low end torque, the 5.43v is not a engine friendly to all levels that a 5.7 hemi is, you don't need H/P to tow, you need torque.
I can't speak for the new 6speed automatic in the ford, but the 4sp auto really killed any performance in a 5.43v ford.
The fact's are that no one wants a truck to ride like a truck, but a truck that rides like a car and can tow like a truck.
All the new ram is is a pasenger car with a box, same with the F-150.
Ten years ago you got less car, but more truck in any domistic pick up, the new trucks don't hold up in the suspension areas.
My old pos o4 f-150 reg cab 4x4 long box whighs more than my 06 2500 reg cab 4x4 long box, and surprise, my 5.7 6sp hemi gets way better mileage.
If you want a real truck, 3/4 are the only way to go.
Old Oct 23, 2008 | 01:09 AM
  #30
TXcharger07
the 6 speed in the ford gives it a nice swift kick in the *** and gets it going alot better. But that was with 4.10's also i believe. The one's ive driven were in a 09 King Ranch Supercrew with the new 5.4L. i'd say about as quick as a first gen hemi.
