Lifted 09 dodge
screw the dealer! my dealer put my 6 in pro-comp on for $500 and i still got my warrenty! it doesnt void ur warrenty, just the parts the lift replaces, which is covered by lifetime warrenty of the lift you buy. so all in all...ur covered!
I have the 6'' PROCOMP stage II on my truck.The geometry remains the same as factory.The angles are not affected,as in driveline,upper/lower ball joints,transfer case,rear pinion angle,front axles,etc...Drop down brackets are used to keep the angles to near factory specifications.I love my suspension lift.The ride is really better than stock!!!For my wheels and tires,I used Helo max 6,with a 4.5" backspacing,and 35x12.50r18 Nitto Mud Grapplers.In june I had a 3" performance accessories body lift installed,and then went to 37x13.50r18 ProComp x-terrains,with 1 3/4" wheel adapters.Had to trim the corners on the lower wind valence on the front bumper to clear tires at full turn,and it looks awsome,as well as the ride....
i have the 6'' procomp stage ii on my truck.the geometry remains the same as factory.the angles are not affected,as in driveline,upper/lower ball joints,transfer case,rear pinion angle,front axles,etc...drop down brackets are used to keep the angles to near factory specifications.i love my suspension lift.the ride is really better than stock!!!for my wheels and tires,i used helo max 6,with a 4.5" backspacing,and 35x12.50r18 nitto mud grapplers.in june i had a 3" performance accessories body lift installed,and then went to 37x13.50r18 procomp x-terrains,with 1 3/4" wheel adapters.had to trim the corners on the lower wind valence on the front bumper to clear tires at full turn,and it looks awsome,as well as the ride....
pics????
