Slight vibration felt through gas pedal?
#121
#122
#123
I'm confused, I thought Moes Performance was selling them as we speak, and with the USB/Power Supply and 180 thermostat?
#124
I know I have totally different engine, but just wanted to let you guys know what worked on mine. In my case I only had vibration between 800 and 1300 rpm and was not related to wheels or the road at all. Mine was vibrating even at idle if I open the TB by hand. So by accident I was going overseas and wanted to make sure that my wife has enough of starting power for Chicago's winters, so I decided to replace battery and alternator. After replacing alternator vibrations disappeared. To be honest alternator bearing was good on the old alternator, so something else mush have been creating that vibration inside and transmitting it to the engine somehow. Or maybe internal diodes were shorted and were creating EMI at certain rpms who knows. So what I suggest try removing your accesory belt and drive for minute or two you will not drain your battery and see if vibrations disappear. At least you will be able to rule out alternator and other pulleys.
#126
As I have mentioned before, my 4.7L has done this from day 1. I took it in and they gave me a 4.7L loaner. Brand new only 300 miles and it had the same problem. When I picked mine up they said the vibration was normal. Days later I took mine in to be detailed and they gave me a different 4.7L as a loaner, again brand new and it had the same pedal vibration.
I think they all do it and I think some drivers just may not be bothered by it.
I did notice that the trucks I drove with the 17inch wheels had more vibration then mine does with the 20" wheels. Not sure if there is anything to the wheels, just an observation.
I would like it resolved so if everyone is planning on calling and reporting the problem let me know. Maybe if enough people call at the same time we can get quicker resolution .
#127
Vibbbbration
I've had my Hemi for 1 month (1500k) now and don't know what to think about it. Thought for sure it had to do with it the fuel saver mode kicking in, but yesterday I drifted into the "wake up" groves cut into the shoulder of the highway. I noticed it amplified the vibaration big time. So now I think suspension? Tires? Don't know. I love the truck otherwise and when I don't think about it it doesnt bother me. Also, does everyones Hemi hum when it kicks into fuel saver? I've got a 07 Durango Limited with the MDS Hemi and I don't notice it.
Mike
Mike
#128
Vibration is gone!
I have suspected for quite some time this was related to tires. Many contributors to this thread do not agree; but this weekend I replace my 275/60-20 Wrangler HPs because after cupping at 3k, the started cupping again at 7k. This, poor wet traction, and other factors made me take the plunge.
I replaced them with Firestone Destination A/Ts. This all terrain tire is quieter and smoother that the Wrangler HP highway tires.
It's like driving an entirely different truck! WOW!
And the vibration so exhaustively described within this thread, that I have had since day 1 ... is gone.
