Remote Start and Security Option
Old Mar 6, 2009 | 01:52 PM
spoon's Avatar
spoon
Default Remote Start and Security Option
Does anyone know if this option includes an alarm?
Old Mar 6, 2009 | 02:07 PM
Doc Fluty's Avatar
Doc Fluty
i have the remote start... and when i installed my XDI intake yesterday i had to disconnect the battery. So when i reattached my negative lead my alarm went off...
so i would say yes.. the remote start includes an alarm
(one thing i dont like about this truck is when your walking away and you lock the doors, it honks. My f150 was silent unless you pressed it two times... in case you wanted your neighbors to notice you locked you truck lol)
Old Mar 6, 2009 | 07:28 PM
lancelanz's Avatar
lancelanz
yes it does include the alarm.
Doc- you can go through the EVIC and turn off the horn with lock. i did it as soon as i got home with mine lol
Old Mar 6, 2009 | 07:56 PM
goatowner's Avatar
goatowner
I have the remote start (09, 2500). When I start the engine from inside the cab I get the alarm indicator light as you would for any of the indicator lights (test mode). However, when I lock the doors with the remote, the alarm indicator light does not go through its quick flash sequence as though arming. It also does not flash periodically to indicate it’s armed. Is there something that I have to do to get this to work? Is it broke? Or did I just not get the alarm?
Art.
Old Mar 6, 2009 | 08:11 PM
Doc Fluty's Avatar
Doc Fluty
you can lance?
is it easy enough you can give me a quick tutorial or at least the page in the book to look for it.. thanks
Old Mar 6, 2009 | 09:18 PM
bountyhunter's Avatar
bountyhunter
I installed an Autostart 2 way LED remote starter - 3000 foot range.
Factory 1 way system has a pathetic range.
http://www.autostart.ca/prodInfo.php?alarm=0&starter=1&tw=1∏=AS-2361TW-FM
Old Mar 6, 2009 | 10:20 PM
Doc Fluty's Avatar
Doc Fluty
2 way led wha?
im finding out all these crazy things after i buy my truck.. like the fuel saver light, 2 way led remote start and a max care warranty.
I should have done more homework!
Old Mar 6, 2009 | 11:09 PM
bigred3297's Avatar
bigred3297
Originally Posted by Doc Fluty
2 way led wha?
2 way led is aftermarket. A 2 way pager is a 2 way communication. You push the lock on your pager, your pager sends a signal to the truck to lock, your truck locks, then the truck tells the pager it is locked, then the pager tells you your truck is locked. It's a 2 way conversation and not a one so your truck can tell you if someone is breaking in or where on your truck it's being touched, etc etc
Old Mar 7, 2009 | 01:11 PM
Sobomaster's Avatar
Sobomaster
I think the range on the factory remote start is just fine. It's like 1000 ft which is plenty for me and I don't have to carry around another FOB or remote thingie.
To do the setup through the EVIC for the honk or no honk, you first need to have the EVIC. Scroll down with the up down arrows on the steering wheel to the last option, Setup. This can only be done when the vehicle is in park. Hit the arrow pointing right to enter setup and then scroll down the options. You can have the truck honk or not honk when it's locked, unlocked, and remote started. You can also configure for the lights to come on, how long they stay on for, etc. It's some pretty useful stuff.
Oh, and yes, if you have the remote start option then your truck does have an alarm - but it will only go off if someone opens a door when the alarm was armed (happens when you lock the truck).
