BAK Flip or Fold-a Cover G4
Old 03-31-2009, 07:01 PM
jaflowers's Avatar
jaflowers
jaflowers is offline
Originally Posted by tuonorider
How much was it?
I had alot done that day so the labor is difficult to break down but the cover was $647. A bit more than real shoppong online will get you but like I said, it's warrantied under the trucks warranty which is lifetime so I felt it was justified.
Old 04-01-2009, 09:16 AM
ShirtaDay.com's Avatar
ShirtaDay.com
ShirtaDay.com is offline
Originally Posted by skidooinit
Does anyone know the difference between the Bakflip and the Dodge cover? Does Dodge use the Bakflip? Which is better? Price difference? Compatible with the Rambox option? Dealer said $755 for the hard cover that fits with the rambox.
The two differences I'm aware of are that the Bakflip sits a little more flush than the Dodge cover and it folds into 4 sections whereas the Dodge cover has 3? Also, the Bakflip can fold back so it stands almost vertical, protecting part of the back of your cab. The furthest most back position for the Dodge cover is the last section, still covering the cab.
Old 04-01-2009, 11:54 AM
sflindsey's Avatar
sflindsey
sflindsey is offline
Does anyone know whether or not the BakFlip and the Bed Utility Rails and the Bed Divider can co-exist? To me it looks like the Bed Utility Rails mount low enough.
Old 05-26-2010, 10:39 PM
gpetry's Avatar
gpetry
gpetry is offline
I would also like to know if the Bakflip will work with the bed utility rails. Has anyone done this?
Old 05-27-2010, 12:57 AM
JRI's Avatar
JRI
JRI is offline
I believe they do but you can call them to check. I installed the BakFlip F1 in the short bed last week and like it a lot. I think it is the only cover that doesn't cover the rail pockets.
Old 05-27-2010, 02:29 AM
cpelton's Avatar
cpelton
cpelton is offline
I installed my F1 yesterday, it is awesome!
Old 05-27-2010, 07:08 AM
TurboGPZ's Avatar
TurboGPZ
TurboGPZ is offline
Where are you buying them and how much are they if you don't mind.
Thanks
Old 06-15-2010, 10:06 AM
Psycareyo's Avatar
Psycareyo
Psycareyo is offline
+1 for more info on the bakflip lowest pricing!
Old 06-15-2010, 10:43 PM
JRI's Avatar
JRI
JRI is offline
dinamitetbs.com is the cheapest I found. BakFlip F-1 is a great cover.
Quick Reply: BAK Flip or Fold-a Cover G4
