Clearing 35's thread.
Old Mar 21, 2009 | 12:00 PM
sarguy01's Avatar
sarguy01
Default Clearing 35's thread.
I took some quick pics of the TRX-4 with a tape measure. Depending on the width of the tires and backspacing of the wheels I think you could clear 35's. Remember, the TRX-4 does come with a front coil spacer. I'd like to know what a regular 4x4's height with the same tires is. Can anyone measure it so we all know?
There is 37" between the ground and the fender. The current 275/70/R17 is 32.4 inches tall.
There is ~5.5" between the top of the tire and the fender flare.
~3.5" from the back of the tire to the flare.
~4.5" from the front of the tire to the flare.
Wheels turned all of the way to the left.
Wheels turned all of the way to the right.
This is where they would rub. Against the upper control arm.
Old Mar 21, 2009 | 12:20 PM
bountyhunter's Avatar
bountyhunter
37.75" fender to ground. Don't see why a 35" wouldn't work if it's no wider than a 33" Wrangler HP.
Old Mar 21, 2009 | 12:29 PM
sarguy01's Avatar
sarguy01
Right. The height of a 35" is not the issue. It is the width that would limit you. The 275/70/R17 has a section width of 10.8 inches. A 35X12.50 is obviously 12.5" wide. So with a new, wider wheel the backspacing would be everything.
Old Mar 21, 2009 | 12:48 PM
switchblade906's Avatar
switchblade906
It all depends on your rim backspacing if you get new rims it would work slot better
Old Mar 21, 2009 | 01:08 PM
sarguy01's Avatar
sarguy01
The 17's are 17x8 correct? If so, a 35x12.50 on an 8" wheel would probably lead to uneven wear. I would go with a 10" wide wheel.
Old Mar 21, 2009 | 01:50 PM
MOPWR2U's Avatar
MOPWR2U
My Laramie measures 37 1/4" between the ground and the fender flare. It is stock and has 275/60R-20 tires on it, that are 32.99" tall according to Goodyear's spec sheet. The diameter measures ~33" with my tape measure, when measured with the weight off the tire (ie. not taking into account the static loaded radius).
So with 35s and a two inch spacer lift its going to be 40" to the fender flare.
Old Mar 21, 2009 | 02:02 PM
bountyhunter
Sounds about right.
Old Mar 21, 2009 | 02:59 PM
sarguy01's Avatar
sarguy01
Yours sits higher than my TRX-4 with a spacer. Do you have a spacer in there?
Old Mar 21, 2009 | 04:18 PM
MOPWR2U's Avatar
MOPWR2U
I just went and looked. No spacer that I can see or feel anywhere at the top of the spring. That TRX spacer must not be to thick. How thick is the spacer on your truck?
Old Mar 21, 2009 | 04:48 PM
sarguy01's Avatar
sarguy01
I can only estimate. 1.5-2". It is up inside the coil perch.
