Lifters making noise on start up
Old Mar 21, 2009 | 10:54 PM
capsfloyd's Avatar
capsfloyd
Default Lifters making noise on start up
Truck sat today till about 5:00 p.m. Went to start it up,sounded like there was no oil in for about 3 seconds . You could here the lifters really loud at that time? 2400 miles on the hemi .
Old Mar 21, 2009 | 11:01 PM
mike2810's Avatar
mike2810
Any indication of low oil pressure? Will be interesting to see if it does it again after sitting for 12 to 24 hours.
Old Mar 21, 2009 | 11:07 PM
sarguy01's Avatar
sarguy01
was it really cold there? did you check the oil level?
capsfloyd's Avatar
capsfloyd
Went out to eat after the start , DID NOT DO IT . Pressure was good ??????
Old Mar 21, 2009 | 11:36 PM
bigred3297's Avatar
bigred3297
Must have been the engine gnomes or the noise was in your head
Old Mar 22, 2009 | 12:41 AM
blue2050's Avatar
blue2050
Not gnomes, my valves have rattled at start up too. 610 miles.
My oil is full and my pressure is good. All mass production engines takes a second to build pressure. Its that second or two..no big deal. Push rod type more than OHC or DOHC.
Its the low weight oil draining out of the top end into the pan and/or cold play.
Old Mar 22, 2009 | 12:56 PM
Lead Head's Avatar
Lead Head
Maybe a faulty anti-drain back valve on the oil filters
Old Mar 22, 2009 | 02:30 PM
uashemi's Avatar
uashemi
Change the oil, use 5w-20 of course for the MDS, the trucks sit for a while after the engines are tested and driven around the lot, on and off the truck etc.
Old Mar 22, 2009 | 07:42 PM
capsfloyd's Avatar
capsfloyd
Started it 6:40 p.m. no noise , oil is full ??????? Don't know what it could have been ????
Old Mar 22, 2009 | 08:46 PM
sarguy01's Avatar
sarguy01
My 03 and 05 always had a slight lifter noise. I put over 50K on both and never had a problem.
