resonators removal
Old Apr 2, 2009 | 11:13 PM
  #31
lastrights's Avatar
lastrights
yeah more sounds fo sure
Old Apr 3, 2009 | 08:47 AM
  #32
panamag's Avatar
panamag
Thank you guys. I didn't want to waste 70 bucks when it could be used to fill the tank instead of handing to someone to cut a pipe. I am definately going to get my resonators removed now that I have seen what you posted. I will poast after and let you know if it is a :-) or a :-(
Old Jun 2, 2009 | 01:30 AM
  #33
TZWC's Avatar
TZWC
Default Aero Turbine 3030XL installed
07 Ram 1500 QC 4x4 Installed Aero Turbine 3030XL muffler ( http://www.aeroexhaust.com/ )with both stock resonator, little louder that stock, untill you punch it. notice some low end torque loss, also notice increase in torque rpm above 3800 rpm.
This was also true on my 4cyl installed header pipe and cat back system notice low end torque reduction, increase in torque around 4k rpm.
I spoke my local exhaust guy, he told me if you want more growl, remove the front resonator.
Old Jun 2, 2009 | 10:39 AM
  #34
72combo's Avatar
72combo
Originally Posted by v8440
I'm still not convinced that the stock muffler is very restrictive. Look at it this way: If someone told you that they had a pair of mufflers that could support 780 honest hp, you'd probably be interested. Well, your dodge dealer does-2 of the stock mufflers on these trucks. Thought of that way, they're not so restrictive are they? Plenty of folks put dual aftermarket mufflers on all kinds of stuff and don't make the 390 hp our trucks do stock.
Sure, they're big. ANY muffler that can flow enough for this much power while being whisper quiet HAS to be big. Now, if you want a louder tone, fine, replace/remove the muffler. I just don't agree that the stock muffler is very restrictive, at least not without someone doing something halfway scientific like measuring backpressure at WOT or putting one on a flowbench, etc.
This might help to confirm your statement. On my 03 Durango there is no replacement muffler, well at the time I had it for 3 years, the reason being after finally getting a rep fromm one of the big muffler and exhaust companies to admit that it already had a high performance muffler and I have a feeling it is the same one or similar to the one on our trucks, it sounds so much like the Durango did, I remember my wife firing it up next the our bedroom when she went to work I loved the sound, truck now is getting to break in a bit and now is sounding like my R/T used to. If you wait a while it will break in and get quite a bit louder...for free! You will not gain nothing but a different sound by changing your muffler.JMHO
Old Aug 15, 2009 | 02:30 PM
  #35
brettp_5's Avatar
brettp_5
Does removing the resonators mess with the factory warranty.
Old Aug 15, 2009 | 04:38 PM
  #36
mxzrevman's Avatar
mxzrevman
i just put a magnaflow muffler on mine, didnt touch anything else
its got just the right amount of rumble to it now
not too loud or too tame sounding
Old Aug 15, 2009 | 09:53 PM
  #37
72combo's Avatar
72combo
Well if the exhaust rusts where you cut it ya it will be affected but as far as anything else the resonator is just to kind of put a screaming child into a machine and they come out with a nice smooth not annoying sound.
Would that analogy work for you guys?
Old Aug 15, 2009 | 09:59 PM
  #38
72combo's Avatar
72combo
I think I would take them off if I had to because I don't like the factory tips, for one you can see the other pipe inside....looks cheap that way, should be chrome as far back as you can see. I think you could get some loudness if you were to put a pipe that widens as it gets to the tip.
Old Oct 27, 2009 | 07:34 PM
  #39
Weinfurtner09's Avatar
Weinfurtner09
Has anyone done this on a Sport since they have the aggresive muffler from Dodge would this get it close to the Mufflex 24 inch one.
Old Oct 27, 2009 | 08:29 PM
  #40
sneeks's Avatar
sneeks
My resonator is gone for different reasons, like the fact it was poorly secured by me and ended up in the road, ran over and in a ditch...
I love the sound, but hate the feeling that something is missing...
So, i caved in. Im swapping my rear bumper out to dual cutouts. Ive also purchased the 16870 magnaflow exhaust system. The system gets rid of the resonators.
I hope to have everything done by Sunday, weather permitting.
