RIDICULOUS Tire Wear
Old Apr 16, 2009 | 05:30 PM
allhans's Avatar
allhans
Exclamation RIDICULOUS Tire Wear
I was never happy with these stock Goodyear Wrangler HPs on my 20" wheels, but this is ridiculous. Look at the wear on my front tires after only 3000 miles! The rear tires look fine.
You can see the inside corner is rounded off due to excess wear. The inside edge is considerably more worn than the outer edge. Some of the tread marks are already gone on the inside. The other front tire is the same. You can also see in the side shot that the individual tread squares are worn unevenly front to back.
Please check your Rams for similar wear.
Old Apr 16, 2009 | 06:07 PM
tombogue09's Avatar
tombogue09
Take the truck to the dealer, that is ridiculous. Its certainly not the tires fault even though the goodyears aren't great. Mine have 12000 miles so far with one rotation and they look perfect.
Old Apr 16, 2009 | 06:09 PM
bigred3297's Avatar
bigred3297
agreed, the dealer should replace those
Old Apr 16, 2009 | 06:11 PM
MOPWR2U's Avatar
MOPWR2U
You need a front end alignment.
Old Apr 16, 2009 | 06:38 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Looks like a toe issue. Negative camber can cause this too, but usually its a little more gradual across the tire unless its way off. The dealer should be able to fix that with an alignment.
Old Apr 17, 2009 | 10:20 PM
allhans's Avatar
allhans
Took the Ram in. Toe was way off...I think it's been that way from the beginning.
Seems better now. Quieter.
The worn tires are now on the rear...should even out.
Thanks for the help.
Old Apr 18, 2009 | 12:00 AM
c0mf0rt's Avatar
c0mf0rt
I just took mine to get the alignment checked and they said they didn't feel the pull but that sucker pulls to the left. I might take it back after this.
Old Apr 18, 2009 | 03:14 AM
daragez's Avatar
daragez
check the alignment....it's ridiculous....take the truck to the dealer...
Old Apr 24, 2009 | 11:05 PM
mrbrown's Avatar
mrbrown
Mine just started pulling to the left this evening. I can't believe a truck with 800 miles is pulling to the left. It's pulls real bad when I brake. Keep us posted on your results. I might take mine to the dealer this week and find out.
Old Apr 24, 2009 | 11:13 PM
Soop's Avatar
Soop
I, too, feel a little pull to the left but have not noticed the tire wear as in the pics. I have almost 2k on the vehicle! I plan to have it checked when I do the first oil change...plus have the outside temp gauge checked on the EVIC!!!
