Fold flat rear floor
Old May 6, 2009 | 05:15 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
Question Fold flat rear floor for crew cab
Does anyone know if the fold flat floor on the quad cab will fit on the crew cab? I realize it will not cover the entire floor, but my 07 had it and my dog crate will slide right in. I have a Cocker Spaniel that likes to make messes if not in the crate on the way to the groomer. My under seat storage does not have the snap but not worried about that. Wondering if I can just remove my lids and install the floor in place of it. Also, did it change any from 3rd gen? I figured I could pick one up at a junk yard.
Old May 6, 2009 | 06:04 PM
Dr. Bill's Avatar
Dr. Bill
I am with you on this one. Dodge should have put the floor on the CC as well as the QC. I miss mine from my 02 big time.
Old May 6, 2009 | 06:07 PM
BubbaRadioNetwork
Yes, I'm currently using a piece of OSB and 4x4's. My floor looks like crap with all the wood dust.
Old May 7, 2009 | 03:28 PM
BubbaRadioNetwork
anyone?
Old May 7, 2009 | 04:35 PM
rolltidehemi's Avatar
rolltidehemi
Doubt it will work, not engineered, but I'm sure you could rig it. I would of rather seen the back of the rear seat fold forward like the mega cab.
Old May 7, 2009 | 05:59 PM
blue2050's Avatar
blue2050
I suspect it will work. It will be short as you mentioned.
Looked at my fold flat and the bracket for it clamps down to the seat mount. Its a separate part.
Here is pictures. I can't explain and I am not sure what the crew seat brackets look like. Decide for yourself if they will work for you.
You can see the fold out simply is clamped in place.
Old May 7, 2009 | 07:03 PM
rolltidehemi
you forget that the cc has the different top to it, I'll look at mine but seriously doubt it will work.
Old May 7, 2009 | 07:33 PM
blue2050's Avatar
blue2050
Just tried to help you.
Old May 7, 2009 | 08:43 PM
SubRammer's Avatar
SubRammer
Is there anywhere that sells the fold flat setup besides the dealer?
Old May 7, 2009 | 09:12 PM
BubbaRadioNetwork
The lids for the crew use the same mounting points. I think if they were removed it would bolt right in place.
