What tires for 2wd street truck?
Old May 15, 2009 | 12:22 PM
Silver Shark's Avatar
Silver Shark
Default What tires for 2wd street truck?
I really want to change the stock rims and tires but can not decide what size to go with. I do tow with the truck but no more than 4500lbs so I think either 20 or 22 rims will work. It just seems like I'm have a hard time finding a street tire that will match the stock tire height. I've seen a few 305/55/20 but most of these are 4x4 tires. And I've found some 305/45/22 but I'm worried there would not be enough sidewall with these for towing. Any help would be great! I would just like a wider more sporty looking tire and rim.
Old May 15, 2009 | 12:38 PM
John Valdes's Avatar
John Valdes
20" tires alone are going to cost at least $1000 for four. (good ones) I would change the rims, but keep the stock size tire. JMHO.
Old May 15, 2009 | 03:17 PM
Dr. Bill's Avatar
Dr. Bill
I really like the Michelin LTX MS in the 20 inch size. I don't care for the Falkens on my son's Silverado. They are not nearly as smooth and they seem to change balance frequently. You can balance them and then after about 2 or 3K miles, they start getting rough and need to be balance again. I have never seen a tire do that.
Old May 15, 2009 | 05:04 PM
Sobomaster's Avatar
Sobomaster
Have you checked discounttire or tirerack? There are quite a few options out there. Discounttire shows 11 options in the stock size of 275/60/20 ranging from $138/ea to $269/ea. These are all (except for 1 or 2) street tires basically.
You could also look for something a little wider if you wanted more grip, but there are plenty of choices.
Old May 15, 2009 | 07:26 PM
Silver Shark
If you look at the stock size (32.99") and then look for wider tires close to 33" it would need to be 305-55-20 (33.21"). I can't find anyone that makes a 305-55-20 in a street tire. The 305-45-22 is 32.81" but that might not have enough sidewall. 305-50-20 would be a very common tire and easy to find but I will loose 1" of overall tire and .5" of sidewall. I just wish I could find a street tire that would be within 1/4 or the stock size. I would like to know what other people have put on their street truck.
Old May 15, 2009 | 08:41 PM
MinatorHemi8's Avatar
MinatorHemi8
Perreli scorps or Michelins, both h rated, both fit stock size, both at tire rack.com a site sponsor.
Old May 16, 2009 | 11:26 AM
Sobomaster's Avatar
Sobomaster
FYI, 305/55/20 on stock rims will rub. Even 305/50/20 rubs a little, but not too bad.
Old May 16, 2009 | 07:45 PM
Silver Shark
Would you need new rims with more offset to run the 305-50-20's without rubbing?
Old May 16, 2009 | 07:47 PM
72combo's Avatar
72combo
On 4x4 also will they rub?
Old May 16, 2009 | 07:50 PM
lancelanz's Avatar
lancelanz
on my 99 ram i had 305/45/22 Hankook Ventus ST tires and i loved them!! i highly recommend them
