UUUGH Valve stems!
Old May 17, 2009 | 07:51 PM
bountyhunter's Avatar
bountyhunter
Warning: USE ONLY PLASTIC CAPS ON TPM Sensors ...metal caps can permanently fuse to the aluminum stems.
Old May 17, 2009 | 08:02 PM
Ryan Albert's Avatar
Ryan Albert
Mine the TPMS metal stems, but with black plastic caps.
Old May 18, 2009 | 07:41 AM
qicvick's Avatar
qicvick
My caps are green because they are filled with nitragion (sp),. the dealer charged 99.00 for this which is a 1 time charge and will be free replacement from now on ( he is on the dropped dealer list, haha, on me) I never noticed and thought this was standard on the 2009s but I noticed this is not mentioned here, they use this trick in airplane tires were I work because the molecules are bigger than air and will not seep thru rubber giving a more consistant airpresure, anybody else with green caps? I am pretty sure they are medel
Old May 18, 2009 | 08:24 AM
wmichell227's Avatar
wmichell227
I have the green caps too. They are the ones that seized to the alum. valves. I hope the dealership will be able to fix them before I leave on Wednesday.
Old May 18, 2009 | 08:31 AM
sarguy01's Avatar
sarguy01
I had no idea and put on chrome caps. They are now seized. Hopefully they will come off...
Old May 18, 2009 | 08:47 AM
wmichell227
BE CAREFUL!!!! I'm going to the dealership on Wednesday, and the more I think about it the madder I get. By Wednesday I should be ready to fight them for new stems at least the 2 that are seized.
Old May 18, 2009 | 07:25 PM
mike2810's Avatar
mike2810
Like a few others my TPMS has black plastic valve caps on the metal stems. No rust that I can see on the valve stems themselves.
Old May 18, 2009 | 08:45 PM
qicvick's Avatar
qicvick
cheaked my green caps, they are plastic
Old May 19, 2009 | 10:07 AM
Sobomaster's Avatar
Sobomaster
Mine are most definitely plastic.
Old May 20, 2009 | 03:11 PM
wmichell227
Took my truck to the dealership today. They replaced the broken valve (TPS) and took the cap off of the other valve. They also replaced all four valve caps with new green plastic ones. Best of all.....it was all covered under the warranty.
Hats off to Dodge City Milwaukee, you will be sorely missed!
