stock 20" wheel backspacing
Old Jul 30, 2012 | 08:54 PM
semo03hemiram's Avatar
semo03hemiram
So if I want them to stick out more do I get a wheel with more backspacing or less backspacing??
Old Jul 31, 2012 | 12:03 PM
MattsMountain's Avatar
MattsMountain
I run stock 20" Rims with Nitto Terra Grapplers LT325/60R20 and had to use 1/4" spacers all around - be prepared to use/need spacers if you go with a wide tire.
Old Aug 2, 2012 | 06:36 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by switchblade906
the offset is +20
Originally Posted by MOPWR2U
Backspacing is actually 5.75"
Originally Posted by rjc799
Which is it?
Both. Offset is the direct cause of the amount of backspacing on a wheel. So, having a 19.05mm offset on a 9" wide wheel results in a 5.75" backspace. Offset is measured from the centerline of the wheel and backspacing is measured from the innerlip to the rotor mating surface.
2002-2008 wheels are 19mm offset w/5.75" BS and 4th Genners are 19.05mm offset so they are .05mm difference. That equates to .02"..aint much at all. Not even noticeable.
This will help you out alot.
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
