Turn Signal
Old Jun 3, 2009 | 11:24 AM
John Valdes's Avatar
John Valdes
Default Turn Signal
A quick tap on the turn signal blinks three times. I think it is standard on the vehicle. However, three is not enough. Can this be adjusted to blink more than three times?
Old Jun 3, 2009 | 11:27 AM
Sobomaster's Avatar
Sobomaster
I do not believe this is adjustable. It was covered in another thread awhile back. Three is standard for a lot of manufacturers. If you need more blinks, then just push it down all of the way until you're done merging or turning.
Personally i think three is plenty for merging and that is when this is used.
Old Jun 3, 2009 | 12:16 PM
Secret Agent Man's Avatar
Secret Agent Man
I 100% agree. Sometimes I bump it accidentally and get three blinks that were not intended. If there were more than three it would be too many.
Old Jun 3, 2009 | 01:44 PM
John Valdes
Maybe I am merging to slowly?
Old Jun 3, 2009 | 03:15 PM
Brandloyal's Avatar
Brandloyal
You must not be from MD. PA. or VA. I don't think anyone around here knows what a blinker is.
Old Jun 3, 2009 | 03:19 PM
Secret Agent Man
It must be similar there to Detroit. When I lived in Detroit, it was a means of survival to use your turn signal after you already start to move over. If you put your turn signal on prior to moving over, the person in that lane would try to speed up to not let you in. Pretty sad really.
Old Jun 3, 2009 | 03:26 PM
Brandloyal's Avatar
Brandloyal
Funny thing is, they will put their arm out the window with a finger pointed up, as if to ask permission while they are in the middle of cutting someone off.
Back on topic, I really do like this feature, and find that 3 blinks is just fine in most instances. I won't lane change unless there is more than enough clearance to do so, the blinker is just a courtesy to let those behind know my intentions.
Old Jun 3, 2009 | 04:20 PM
jawsdc's Avatar
jawsdc
no three blinks here, very sad...
Old Jun 3, 2009 | 05:35 PM
Doc Fluty's Avatar
Doc Fluty
i wasnt aware of the three blinkin prob.. mine blinks many times... maybe you have a preejacublinking problem that should be check so you can blink longer
Old Jun 4, 2009 | 10:29 AM
John Valdes
I wish I understood what you said?
