Here is the Plan for the 2009 Ram 1500 4x4
Old Jun 4, 2009 | 10:42 PM
lross78550's Avatar
lross78550
Default Here is the Plan for the 2009 Ram 1500 4x4
11111
Old Jun 5, 2009 | 02:40 AM
c0mf0rt's Avatar
c0mf0rt
After doing a deck install I can tell you that will probably be the easiest thing you do with the whole process. Good luck!
Old Jun 5, 2009 | 10:25 AM
tbagr's Avatar
tbagr
I see when I bring up the link it lists your mods at the bottom. Question, the Lockpick V2.....where purchased, $$ and who installed? Hard?
Also, I want to change out the sub to get more "kick" out of the system. I have the Alpine system. Can a person swap out the factory with a 10" (or whatever size it is) with an aftermarket and call it good or should an amp be added as well? I think the stock system sounds decent with Sirius / Radio and MUCH better with CD or IPOD! Also, do you (or anyone) know anyone with the IPOD cable so one can control IPOD from head unit?
Thanks and nice truck!
Old Jun 5, 2009 | 11:58 AM
lross78550's Avatar
lross78550
Old Jun 5, 2009 | 06:00 PM
sarguy01's Avatar
sarguy01
Please post pics of the install and let us know where you put the amp/etc.
Old Jun 5, 2009 | 11:09 PM
lross78550's Avatar
lross78550
Old Jun 6, 2009 | 01:31 AM
2009detonateryellow's Avatar
2009detonateryellow
Really the hard part is done. Speakers are a breeze to install in the doors. Tweeters are just as easy. I just finished my install last weekend.
REN- Headunit
Lockpick (video out to two Sony 8" Dvd Monitors)
Diamond Audio 90x4 to Diamond Audio 6x9's in doors (dynamat behind) and Diamond Audio tweeters in dash
Diamond Audio 400x1 to two Boston G210 subs
Audiocontrol 3xs Crossover
2.0 farad Cap
PAC CHR-3 plug in line out adapter (no splicing)
1/0 power cable from Battery to splitter
Sounds aaaaaaaamazing!!!
Good luck on your install!
Old Jun 6, 2009 | 02:58 AM
lross78550's Avatar
lross78550
Old Jun 6, 2009 | 11:14 PM
2009detonateryellow
Wink I must suck then. lol
Originally Posted by lross78550
Sounds like a very nice system i like your amp and spks, i have some questions you have a 2009 ram 1500 right?
1st) how did you install the dynamat? did you pull off the black plastic inner door panel? if so where inside the door did you put the dynamat?
2nd) the pac C2A-CHY3 says its for use only on cars with a "premium" audio system? did you have factory amps? The whole reason i bought the audiocontrol lc6i line output converter is because i couldnt find a pac product that says it would work?!? the lc6 is going to make installing the amp alot more work, using the c2a-chy3 do you still have fader contol?
man if all you had to do is plug that in and run rca's to your amps then you suck for being smarter than i am
Please answer if you have time these are questions i have really been looking for an answer to.
Thanks
Lee
Sorry to inform you everything just plugged right in and I ran rca's to the crossover. send me a private email to derrillv@juno.com and I'll give you my number so you can call me. It'll be easier than emailing. Derrill
