09 ram oil change
Old Jun 16, 2009 | 10:40 PM
MOPWR2U's Avatar
MOPWR2U
I changed my oil for the first time at 1000 miles, and switched to Mobil 1 5w20 synthetic at that time. I changed the oil for the second time at 3000 miles, and plan to change it every 3000 miles thereafter. I have 4000 miles on the truck now, and I tow every weekend, often on dirt roads.
MOPWR2U
Old Jun 18, 2009 | 11:44 AM
John Valdes's Avatar
John Valdes
Well, I now have my answer. I have 2200 miles on mine and am leaving for a road trip next month. My original question was or would have been "should I have it changed before I leave. Now I know I will.
I know the dealer uses bulk oil. How can I be sure he uses 5w20? Thanks everyone.
Old Jun 18, 2009 | 02:23 PM
PurplDodge's Avatar
PurplDodge
Bring your own.
Old Jun 18, 2009 | 03:57 PM
dodgewasp's Avatar
dodgewasp
Originally Posted by Dr. Bill
Many new cars are shipped with synthetic oil in them from the factory. Synthetics are no "slicker" than mineral based stock so break in is not an issue. Synthetics do have a benefit in that they do not have paraffins and other impurities that were not able to be refined out of the mineral base stock. The hydrocarbon chains of synthetics also do not break down as easily and do not contain viscosity enhancer molecules that break down lowering your viscocity rating over time and use. That being said, I recommend that you change your oil at 2,500 and 5000 miles, then every 5,000 miles afterward. You can use any quality name brand oil you wish. I think the best for the buck is Motorcraft Synthetic Blend 5W20.
Motorcraft Synthetic Blend 5W20 Yep....best bang for the buck. Changed mine out at 1,300 miles. Will change every 5,000 thereafter.
Dodgewasp
Old Jun 18, 2009 | 04:41 PM
PurplDodge's Avatar
PurplDodge
I have heard the that the Motorcraft oil is high quality stuff. Their filters are also good (Purolator makes them).
Old Jun 18, 2009 | 05:08 PM
oldjeep's Avatar
oldjeep
How do you know your dealer won't pee in the crankcase? Jeez. Dodge recommends that oil for a lot of cars, the dealer will have it.
Old Jun 18, 2009 | 05:43 PM
72combo's Avatar
72combo
I called the dealer and asked if they have 5 w 20 in bulk they said yes a lot of cars use it now, in fact all the HEMI.s my Avenger does also 2.7 l v6. So I don't think it will be a problem, and since it is bulk you only pay a couple bucks more for the extra oil compared to over 10 bucks it would be in litre/quart bottles.
I was told by someone, can't say but even if you change your oil you still have to reset the oil meter or whatever. I know this because we took my sons Avenger in for an oil change, the light had not come on but I felt it was time...he is 18 he has to be driving the **** out of it so we go get one. On the way back the light comes on for the oil change. We stopped right away thinking they forgot to tighten something and we were low. So checked it all, full, clean, all good so we reset it and it hasn't come on since and it has been close to 5 g's and it would have come on the last time at 3000 but i think i had not been reset before that. This reset thing is just a reminder that is not at all reliable as far as I am concerned. I think we should be able to set our own times as long as they are within the warranty standards. Like I am a fan of 3000M/5000km or 2/3 months depending on how you drive , traffic, dust.etc.
Last edited by 72combo; Jun 18, 2009 at 05:52 PM. Reason: Hit enter by mistake before done.
Old Jun 18, 2009 | 05:57 PM
sarguy01's Avatar
sarguy01
^^^ Actually, it is more then a reminder light. We have a viscosity meter that checks the oil as well, if I remember correctly.
Old Jun 18, 2009 | 06:07 PM
72combo's Avatar
72combo
I was just looking at my manual and all 3 engines for this truck take 5W 20 oil ..So I am gonna say that Dodge has changed all their standard oil probably except for heavy duty???? It doesn't make sense thinner oil, lasts longer? I know it's necessary for the Hemi MDS but what is with the other engines?
Old Jun 18, 2009 | 08:56 PM
MinatorHemi8's Avatar
MinatorHemi8
Originally Posted by sarguy01
RP is great stuff, but may be too much for us, IMO.
I am going to get a 6000 mile sample of Castrol synthetic tested soon, but I am sure it is going to be fine.
engine finally blew in the 1998 dodgeram 1500 laramie with a viper v10, castrol synthetic used since day one changed every 4,000 miles at 236,000 miles it was ful of carbon in the engine almost clogged full , no more castrol for me.......
