2009 Ram 1500 wheel bolt pattern
Old Jun 19, 2009 | 04:31 PM
chris66's Avatar
chris66
Default 2009 Ram 1500 wheel bolt pattern
Anybody out there knows what the bolt pattern is on the 2009 ram 1500s?
I am looking at getting some cheap steel rims to use with off road tires but need to know the bolt pattern. I have contacted the parts and service department at the dealer and surprisingly they couldn’t answer the question .
Any help will be much appreciated.
Thanks,
Chris66
Old Jun 19, 2009 | 04:39 PM
2009detonateryellow's Avatar
2009detonateryellow
Default Wheel Bolt Pattern.
5 on 127 (5 on 5).
That's what my 22" Rich Evans Designs are. They are my summer wheels and I switch back to factories for the winter.
Derrill
Old Jun 19, 2009 | 07:38 PM
Ryan Albert's Avatar
Ryan Albert
5x5.5
Old Jun 19, 2009 | 08:56 PM
oldjeep's Avatar
oldjeep
Old Jun 20, 2009 | 01:32 AM
72combo's Avatar
72combo
well which one for sure here I see 2 for sure maybe 3
Old Jun 20, 2009 | 02:52 AM
cpelton's Avatar
cpelton
they are 5x5.5
Old Jun 20, 2009 | 09:43 AM
switchblade906's Avatar
switchblade906
5x5.5 is the same as 5x139 i think
Old Jun 20, 2009 | 10:03 AM
oldjeep's Avatar
oldjeep
Pretty close. 5x139.7 is the same as 5x5.5
A lot of manufacturers seem to just list them as 5x139
Old Jun 20, 2009 | 07:32 PM
2009detonateryellow
Default 5 on 5's on mine.
I don't know if stock tire size has anything to do with it but mine came stock with 20" wheels that are 5 on 5. Chris66 check with your local tire shop.
Old Jun 20, 2009 | 07:50 PM
oldjeep's Avatar
oldjeep
Ou of curiosity, what makes you say that your wheels are 5 on 5? Wheel shop told you, or you measured? Because if they are 5 on 5, then someone built you a couple custom axles.
