satellite glitch
Old Jun 21, 2009 | 05:52 PM
Inbred's Avatar
Inbred
Default satellite glitch
Just thought I'd throw this out there for everyone. had a glitch in my sat radio. Lost signal when I shut off my truck under the roof to get fuel, normal. But when I left, it would not re-acquire signal. Turning radio off and on did nothing, as did switch to cd and fm. Shut the truck off, and re-started, and that did the trick.
That seems to be the solution for all of these little computer glitches, turn off truck and re-start.
I have one of the non-mygig sat radios.
Old Jun 21, 2009 | 06:27 PM
CarGuyOhio's Avatar
CarGuyOhio
I lost signal a couple weeks ago. I usually do loose it on this little section of road due to LOTS of trees. When I came out it did not come back, did not think twice, changed to FM and on my way home put it back to SAT. Like I said, did not think anything of it, chalked it up to a comm issue.
Old Jun 21, 2009 | 07:32 PM
turk1270's Avatar
turk1270
its just a satellite radio thing hasnt happened in my ram yet but it has happened in my other vehicle with xm
Old Jun 21, 2009 | 08:48 PM
Hdcowboy's Avatar
Hdcowboy
I lose my sat signal every evening as soon as I pull in the driveway and get under the metal carport. I wouldn't say its actually a glitch its just that it cant pick up the signal under there. I never lose/lost the signal anywhere else and as soon as I back up from under the carport I get my signal back immediately though.
Old Jun 21, 2009 | 09:51 PM
drober30's Avatar
drober30
I lose my signal often just going under bridges on the expressway. Very sensitive bad antennas on the truck! I've had sat radio on other vehicles, aftermarket and factory and this Ram is the worst.
Old Jun 21, 2009 | 09:57 PM
lross78550's Avatar
lross78550
welcome to satellite radio, im a 2.5 year subscriber and sometimes i can cough loud and loose signal.
Lee
Old Jun 21, 2009 | 10:31 PM
Hdcowboy's Avatar
Hdcowboy
Just thank God it aint as bad as satellite TV!!!
Old Jun 21, 2009 | 11:18 PM
Laramie1997's Avatar
Laramie1997
On our GM it's not too bad.
I added it to my truck about 3 years. If it becomes a bi issue, you can swap antennas out for a high gain. It helps a lot around trees.
Old Jun 22, 2009 | 04:44 PM
Inbred's Avatar
Inbred
Losing signal wasn't the glitch. Trust me, I know how it works. That it never acquired signal for 5 miles after the sky was clear until I shut the truck off, that was the glitch.
