My Retrofit Camera
Got a great deal on my 2009 Laramie, but it did not have the rear camera that is so handy when hitching/towing. Due to all the delays with the OEM cameras being backordered, I went ahead and went with something else. I purchased the allgig from nav-tv (let's you watch DVD's and work navigation while moving, and input camera) and the a CCD camera from a seller on ebay. The resolution on these CCD cameras is just plain awesome, day or night. Install was pretty easy and only took a couple of hours. I took the handle out and made the hole with a Dremel tool. I put it where the keyhole would go, since I don't have a locking tailgate, but can also be installed to the left of the handle. Bottom line, this is something that can be done easily, faster and cheaper than waiting for the dealer to get the camera and do the install. Just another option for those wanting to do this.
Here are some pictures:
great job...i was thinking the same thing...i just didn't which camera to get. care to share the ebay seller? did the kit come with a mounting kit and the finish ring? install looks factory!
Here is the link to the one I installed. It comes with several different rings so you can angle it if needed.
http://cgi.ebay.com/HQ-CCD-WIDE-VIEW...3%3A1|294%3A50
If you are going to place it to the left of the handle, you might want to order the one with the built in IR. This camera is a little shorter which is better, since the one I used might interfere with the interior mechanism of the handle IF installed to the LEFT of the handle.
http://cgi.ebay.com/CCD-INFRARED-KEY...3%3A1|294%3A50
As for video quality, it's probably the best I have seen and I have had factory cameras on my past vehicles, BMW and Infiniti. I honestly don't think that the IR's make a big difference at night. The camera I have does not have the IR's and the night time view is simply awesome. Just make sure you get a CCD camera. It is well the worth the extra money.
questions..
1. i dont have the nav.. but i do have the touch screen hard drive version. so will this camera work with my unit?
2. how does it hook up? are there rca jacks in the back to run it too..
3... umm... anything else we should kww?
thanks.. and nice clean install bud
Trending Topics
