linking the keys to seat memories settings
Old Jun 29, 2009 | 08:07 PM
Phil Des 09laramie's Avatar
Phil Des 09laramie
Default linking the keys to seat memories settings
Hi all.
I was wondering if anyone has been able to link keys to the seat memory settings?
for those with laramies ( or possibly other models) with the power seats I believe that you can program individual keys (ie mine and my spouses) to automatically set seat and the other parameters memorized by the seat mounted memory buttons by inserting the appropriate key in the ignition
I have run thru the procedure depicted in the manual without success.
I was wondering if anyone has succeeded.
If so how??
Old Jun 29, 2009 | 10:39 PM
Chaosrawn's Avatar
Chaosrawn
I think I succeeded (followed the manual), but I'm the only one who drives my truck, so it may be it is not working!?
Old Jun 30, 2009 | 07:20 AM
Phil Des 09laramie
I tried again last night without success.
It's not a big issue as she does not drive it often its just a question of principals.
If its supposed to do it well it should..
Ill let the dealer deal with it.
Come to think about it, if they were bright the settings would take effect when you use the remote
to unlock the door and not when the key is turned in the ignition.
My wife being well vertically challenged, our seating positions are quite different and I have a tuff time getting in after she used it.
I guess the solution would be to not let her drive it... hahahaha Shhhhh!
Old Jun 30, 2009 | 07:30 AM
qicvick's Avatar
qicvick
I haven't tried it as my wife and I use the same setting( car I drove all thru highschool seat was pretty far foward and wouldn't adjust and just learned to drive like that), however I do have the easy entry activated were the seats go all the way back when you pull the key out, sounds like you don't ,wondering if that needs to be activated in order for seats to adjust, mine stay all the way back till you put the key in
Old Jun 30, 2009 | 08:37 AM
Chaosrawn's Avatar
Chaosrawn
I just checked; mine adjusts seat, mirrors and radio (pedal position too, I think) to desired settings for me. This happens when I unlock with my key fob. It had to be synchronized by me before this would happen though. Found instructions in the manual somewhere.
Old Jun 30, 2009 | 09:22 AM
Phil Des 09laramie
The "easy exit function" works fine its just that my wife raises the seat quite a bit as well as move the pedals forwards..
I will try again it I cant get it, I will tell the dealer..
Old Jun 30, 2009 | 09:23 AM
Phil Des 09laramie
Im glad to know it works. I will run thru the procedure again after the fishing trip..
Old Jun 30, 2009 | 09:31 AM
72combo's Avatar
72combo
Bring the book with you in case it rains while you are fishing. I say that because it always used to rain when I went fishing or camping or anything outside.
Old Jun 30, 2009 | 10:34 AM
cskubis's Avatar
cskubis
I just followed the instructions in the manual and got mine to work fine ... unlock w/ my keyfob --> my settings; unlock w/ her keyfob --> her settings.
