Dual Headlamp to quad?
Old Jul 15, 2009 | 04:33 AM
devile's Avatar
devile
Default Dual Headlamp to quad?
Is it possible to do the swap... If so could I run the H11 (low & high bulb) in the low beam part of the quad?(if so, would the high actually work?) And use the High beam light hole for something else???
Anyone have an idea behind it???
Old Jul 15, 2009 | 04:00 PM
savage_46's Avatar
savage_46
im assuming you want to put in the quad headlight housings but retain your dual headlight setup, right?
dual setup uses H13 bulb. quad uses H11 for low & 9005 for hi. not sure if H11 will plug into H13 connector or fit the housing hole. i have an H13, but no H11 to compare it to. so i guess theres only one other way to find out, unless someone else on here knows.
Old Jul 16, 2009 | 07:10 AM
devile's Avatar
devile
Well ya, just want to use the original bulbs (whatever they are) in the quad setup... I guess relaly the only way of explaining it... I guess I will go look at another truck, and pull the bulb out and see if it'll fit in mine... I dunno, we will see... lol
Old Jul 16, 2009 | 10:56 AM
Thatmarkguy's Avatar
Thatmarkguy
You can't use the H13 bulbs in the H11 housings, the openings are a different shape. You'd probably be better off with your non-quad headlights if you use your high beams a lot. The high beams on the quad lights suck, actually the fog lights put out more light than the high beams.
Old Jul 16, 2009 | 12:52 PM
j0e's Avatar
j0e
id like to see these quad lights you speak of.
Old Jul 16, 2009 | 01:11 PM
devile's Avatar
devile
Look on the sports, and some SLT's they have the small headlight and the big one, lol...
Thanks for the info...
Old Jul 16, 2009 | 10:34 PM
Inbred's Avatar
Inbred
The light swap will work; the normal wire plugs into the quad light, where it is split to each beam and bulb and ends with a different connector. Regarding using a dual bulb in one of the quad lights, no it won't work. Just out of curiosity, what do you want to put in the other light?
Old Jul 16, 2009 | 11:18 PM
devile's Avatar
devile
Do traffic control part time with my truck, and would be an awesome stock look setup for a strobe, instead of drilling into my housing...
Old Jul 17, 2009 | 10:46 PM
Inbred's Avatar
Inbred
Gotcha. Unfortunately I think you're out of luck.
Old Jul 22, 2009 | 01:27 PM
savage_46's Avatar
savage_46
i was wondering how many other people noticed. its pretty pathetic how little light they put out.
