Bakflip G2 Installation on 09 Crew Cab with Drop In
Old Sep 24, 2009 | 10:49 PM
  #21
moparfreak77's Avatar
moparfreak77
I got the G2. It has rained a bit since I put the cover on and little came in the box, less than I would have thought actually. Is it possible oldjeep for you to take a pic of the front seals? I will try to post a pic of the area.
Old Sep 24, 2009 | 10:54 PM
  #22
moparfreak77
This spot...
Attached Thumbnails Bakflip G2 Installation on 09 Crew Cab with Drop In-p9230602.jpg
Old Sep 24, 2009 | 11:12 PM
  #23
oldjeep's Avatar
oldjeep
I can take one sometime tommorrow. Your problem there seems to be that you have a plastic bedliner that hangs over the front rail and doesn't go all the way to the side caps. Might need to stick some weatherstrip in the gap on each side.
Old Sep 25, 2009 | 04:04 PM
  #24
moparfreak77
Maybe I can just cut the bedliner where it contacts the tonneau rails, then it can go all the forward.
Old Sep 30, 2009 | 04:55 PM
  #25
TlmGlk19's Avatar
TlmGlk19
I just bought the G2 and am waiting for delivery. I too was wondering where the drain tubes would go. I have the factory drop in bed liner. I have notice an opening on the bulkhead rail that I could put it through, but it seems like the water would have to run uphill to drain. Maybe once I do the install it will become more clear. Any info though would be appreciated.
Old Sep 30, 2009 | 05:44 PM
  #26
oldjeep's Avatar
oldjeep
You drill 2 holes in the bedliner where the holes in the bed are.
Old Sep 30, 2009 | 10:42 PM
  #27
moparfreak77
I stuck my hoses out the holes in the bedliner where the tie-downs are.
Old Oct 1, 2009 | 08:58 AM
  #28
Ant2537's Avatar
Ant2537
Do you have to cut the top of the mopar drop in liner to install the G2?
Old Oct 1, 2009 | 11:22 AM
  #29
oldjeep's Avatar
oldjeep
Doesn't that just dump the water between the bedliner and the bed?
Old Oct 1, 2009 | 08:50 PM
  #30
moparfreak77
It can come out in the front of the bed since the seams arent that tight. No different than if I had no tonneau and no bedliner.
