Bakflip G2 Installation on 09 Crew Cab with Drop In
4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a quick question. For anyone who has the Bakflip and a drop in bedliner, where did you run the drain tubes? Is there a drain plug that is covered by the bedliner? Thanks for the help.
Also, did you use shims for the install? Mine didn't come with any.
I didn't get shims or use any, but I did cut a piece of the foam you put on against the bed and placed it near the tailgate part of the rail to stiffen it a bit when it closes.
In that picture it looks like the rear seal is folded under the cover. Did you shut the tailgate without opening the BakFlip? If you have left it like that, the seal is probabally messed up and needs to be replaced now.
The side seal does look a little screwy too. On mine it was molded down at the end of the rail.
