No hitch? I need a pic!
Old Sep 19, 2009 | 01:58 PM
CarGuyOhio's Avatar
CarGuyOhio
Default No hitch? I need a pic!
I found 30 minutes today and thought I am going to take off my hitch. If I ever need it I will just put it back on.
Anyhow, I started then realized if I pull this thing out my bumper will not be tied to the frame anymore. So obviously I need a bracket. See attached pic. The circle is where the hitch attaches to the bumper bracket, then the hitch attaches to the frame as you can see. If you could take a pic of the same spot on your truck I can print and take to the dealer with me so I know I am asking for the right stuff.
Old Sep 19, 2009 | 02:31 PM
c0mf0rt's Avatar
c0mf0rt
WTH would you take if off for? Should've bought a kia...lol
Old Sep 19, 2009 | 03:26 PM
CarGuyOhio's Avatar
CarGuyOhio
The only thing I may ever pull is a trailer with a car on it. The hitch will eventually start to rust and look bad. As I said, if I need it I will put it back on.
If I was going to pull serious stuff I would not have bought the 1500!
Old Sep 19, 2009 | 04:50 PM
CJDTAUTOTECH's Avatar
CJDTAUTOTECH
just get teh same peice without the hitch. I changed mine when I got into a wreck, you can order the reinforncment with or without the hitch, the add on kit was like 100.00 and teh differnce was only 4o dollars between the 2 and now I ahve a welded one . only thing I made out on after egtting rearended, was happy they totaled teh Chevy that hit me!
Old Sep 20, 2009 | 02:35 PM
deeko2007's Avatar
deeko2007
ya what he said! it's not a car
Old Sep 21, 2009 | 09:26 AM
CarGuyOhio's Avatar
CarGuyOhio
Thanks for the pics
I will take a look at one on the lot before I walk over to parts.
Old Sep 21, 2009 | 01:13 PM
Doc Fluty's Avatar
Doc Fluty
i took my hitch off and the guy who took it off had to give me his support. i thought you could just unbolt it.. nope
Old Sep 21, 2009 | 01:28 PM
CarGuyOhio's Avatar
CarGuyOhio
I realized that fairly fast in the process, although I did leave 4 bolts out for now, not hurting it as long as I am not pulling anything. Also thought about the trade thing, but I want to keep my hitch in the event I do need to tow. You can never tell when I may be hauling home some old pile of crap car.
Old Sep 21, 2009 | 01:39 PM
wellstep's Avatar
wellstep
You should do the trade and then use the piece that bolts on to that would be a lot easier to do. When I boight my truck it had just the bar told them I wanted the class IV hitch showed up to pick up the truck and they had the bolt on piece on made them replace the entire bar with the welded hitch. If you can get someone to trade the you can get the bolt on piece from the ebay for like $80 I think. Here is the link to Mopar Accessory site they have the instructions there as well.
http://www.mopar-accessories.com/en-...=3055&pc=52614
Old Sep 21, 2009 | 02:05 PM
oldjeep's Avatar
oldjeep
Why bother? If all he plans on towing is a little car trailer, just stick a ball on the bumper - it's rated for 5K lbs all by itself.
