Bullydog installed
Old Feb 15, 2010 | 10:10 AM
  #41
mixgt's Avatar
mixgt
I believe the sensitivity is in the special options part of the menu. I havent been ablle to change the way the tranny shifts, just at what RPM it shifts.
Old Feb 15, 2010 | 10:56 AM
  #42
Collie's09's Avatar
Collie's09
Originally Posted by BigTexMarine
i believe that you can switch it back to factory settings before you take it in and they will be none the wiser.
Yes I know you can switch it back to the stock setting however I'm pretty sure they can tell that the computer settings have been tampered with while doing an investigation. Please someone correct me if I'm wrong because I hope I am. I would want to be 100% sure that they couldn't tell before I did this..
Old Feb 15, 2010 | 03:56 PM
  #43
c0mf0rt's Avatar
c0mf0rt
Anybody change their tire size with it? I used a tire calculator and 33.3... I used 33.2 in the bully and my speedometer is actually reading faster than I'm really going (compared with the wife's jeep). I've moved it down to 33.0 to hopefully compensate a little. Just wondering.
Old Feb 16, 2010 | 10:06 AM
  #44
mixgt's Avatar
mixgt
You are re flashing the computer. Before the truck goes in for service, re flash the computer back to stock. They cannot see that anyone has been into the computer.
Old Feb 25, 2010 | 05:29 PM
  #45
Jakeshemi's Avatar
Jakeshemi
what is this transmission control that SC is coming out with, when will it be out. and is it going to be that much better the BD?
Old Mar 10, 2010 | 01:02 PM
  #46
bls8195's Avatar
bls8195
So do you think this programmer is better than Superchips?
Old Mar 10, 2010 | 02:32 PM
  #47
72combo's Avatar
72combo
Originally Posted by socaliallstar82
eh i doubt it, sales are pretty healthy (as healthy as any full size truck maker anyways), and i see a bunch of them on the road. And they just added a new 4.6 motor to the line up as well as made the newer 5.7 E85 as well. Also talks of a diesel in the near future. Im sure theyre gonna be around for a while.
Just curious and serious how are the sales now? How has the recalls affected sales?
Old Mar 10, 2010 | 02:35 PM
  #48
72combo's Avatar
72combo
Do any make the tranny shift different? I always thought that only shift points could be changed. Could a tuner be used for the opposite for total gas mileage lift shift points down instead of up, but I suppose that would cause ping for sure.
