Ugg - tailgate lock frozen
Old Oct 13, 2009 | 10:14 AM
oldjeep's Avatar
oldjeep
Default Ugg - tailgate lock frozen
Weather got cold and now my tailgate will not unlock. Hard to tell if it is the power solenoid or the latch itself. Can't be unlocked with the fob or with a key, it just won't turn far enough. Hoping that as it sits in the sun that it will un freeze whatever has happened.
Old Oct 13, 2009 | 11:57 AM
kasjun's Avatar
kasjun
Might want to try spraying with a warm can of wd-40. Sometimes this will work. It is good at displacing moisture.
kasjun
Old Oct 13, 2009 | 05:58 PM
oldjeep's Avatar
oldjeep
After work it was back to working fine. Hopefully this won't be an on-going problem when the temp drops below freezing.
Old Oct 13, 2009 | 06:10 PM
CarGuyOhio's Avatar
CarGuyOhio
The gate will not unlock with the FOB, that is unless you put on a "special" add on you can get at the dealer.
Old Oct 13, 2009 | 06:40 PM
oldjeep's Avatar
oldjeep
No kidding
I've got the Mopar power lock on my tailgate.
Old Oct 13, 2009 | 09:07 PM
CarGuyOhio's Avatar
CarGuyOhio
What did it cost?
Old Oct 13, 2009 | 09:16 PM
oldjeep's Avatar
oldjeep
What did it cost?
I got it for Fathers day from my wife, but it costs about $120 and took me an hour or 2 so to install.
https://dodgeforum.com/forum/4th-gen...k-install.html
Old Oct 14, 2009 | 01:54 PM
72combo's Avatar
72combo
That will be the difference between the Pace Edwards and the original, the pace lock is way up under water never gets near it the handle is what gets locked so even if we have a lock or not the latch could freeze. Mine opens with the fob, you just tap into either the drivers of passenger door lock wires. Simple as pie, even supply 2 relays to make it all tidy and Dodge can't say anything wrong with the wiring.
