How do I take off my door panel?
Old Oct 19, 2009 | 01:13 PM
falconv's Avatar
falconv
Default How do I take off my door panel?
Trying to replace my mirror and cant figure out how to take off the door panel to get to the wireing does any one have how to or no where i can find a how to. Thank you for your time.
Old Oct 19, 2009 | 05:36 PM
falconv's Avatar
falconv
Bump??????
Old Oct 19, 2009 | 05:41 PM
craiggles09's Avatar
craiggles09
most dodges have little white pieces of plastic that you can just use a large flat blade screw driver to get off.. but there is a tool out there that will do it a lot easier. and they just snap right back into the holes on the door
Old Oct 19, 2009 | 11:36 PM
jason2922's Avatar
jason2922
in other words, pull from the bottom and work your way up... the top normally has a lip and sits against the window which will need to be lifted off of. check for plugs or hidden screws near the handles or trays. all doors are about the same, careful with the white plastic clips that craiggles09 said, they break very easy...
Old Oct 19, 2009 | 11:43 PM
lowriderman1225's Avatar
lowriderman1225
DO NOT try to pry them off like the old style like stated by craiggles09, the 09 ram is easier then that. All you have to do is remove the black torx looking screws around the panel, be careful they are plastic, remove the black press in clips after you remove the torx screws. pop out the window/lock switch, unscrew the plastic piece behind the door handle, pop out the small plastic piece right behind the side mirror, than simple lift up on the panel and it will come right off.
Old Oct 19, 2009 | 11:44 PM
jason2922's Avatar
jason2922
good deal and looking out
Old Oct 20, 2009 | 09:50 AM
72combo's Avatar
72combo
Pretty cool looking design for the installation of the window. Looks like no more scratching the frame of the door? When you get your door panel off you will see what I mean.
Old Oct 20, 2009 | 08:22 PM
Inbred's Avatar
Inbred
see this thread for detailed info:
https://dodgeforum.com/forum/4th-gen...y-install.html
