Lights Behind Grill
Old Dec 29, 2009 | 11:56 AM
  #21
TRXHemi's Avatar
TRXHemi
How hard is it to get the grill off? My Dad just got an '09 and wants some lights behind there.
Old Dec 29, 2009 | 03:12 PM
  #22
Huff360's Avatar
Huff360
It's pretty easy. Takes about 10 minutes or so. The hardest part is getting the clips along the bottom to come loose. I have seen where some guys put blue painters tape on the bumber under and just in front of the grill to avoid scratching the bumper. I didn't find that necessary though.
Old Dec 29, 2009 | 04:02 PM
  #23
jason2922's Avatar
jason2922
Really easy,
1. Open the hood, take the top plastic cover off, push in clips hold it on.
2. It will expose 4 bolt heads on the top, remove those.
3. 2 main clips hold it on at the base of each side and 2 alignment lips in the center at the base. It will lean out towards you and add pressure pulling out. It will then pop out. Done.
