Led cargo lights
Old Oct 30, 2009 | 10:08 PM
daprincipal's Avatar
daprincipal
Default Led cargo lights
I just purchased some LED lights to replace the factory cargo lights. These should come in handy when we camp, etc, and we need to see in the bed of the truck. The stock ones just aren't bright enough. Reason for post is to see if anyone else has had to replace these or upgrade these. I took the two screws out and tried to remove the assembly but it won't come out. Is there a trick to this? Any help would be appreciated.
Old Oct 30, 2009 | 10:57 PM
tlyons68's Avatar
tlyons68
check these out they are great bluewaterled.com you can mount them anywhere with 3m tape
Old Nov 1, 2009 | 06:58 AM
daprincipal
Still looking for help on how to get the rear cargo light assembly off.
Old Nov 1, 2009 | 07:07 AM
tombogue09's Avatar
tombogue09
The service manual says you just pull it out
1.Disconnect and isolate the battery negative cable.
2.Remove the two screws (1) that secure the Center High Mounted Stop Lamp (CHMSL) (3) to the rear roof header panel.
3.Pull the CHMSL away from the opening in the roof header far enough to access and disconnect the headliner wire harness connector (4) from the pigtail connector on the back of the lamp housing.
4.Remove the CHMSL from the roof header.
1065086.jpg?t=1257078274
Old Nov 1, 2009 | 11:08 AM
kxwhite's Avatar
kxwhite
I found that some bed lights work best because the cargo lights can blind you when your looking in your box (with the cover on) i put some Reacon led bed lights in and they work Great!
Old Nov 1, 2009 | 03:34 PM
turk1270's Avatar
turk1270
well i hate to be the bearer of bad news but the leds will not be brighter than the stock 921 18w factory bulbs. i switched mine and i tried 2 different leds and they both stayed partially lit even when switched off.i dont know if they would eventually would go out because after seeing them still on i removed them and but the 921 bulbs back in
Old Nov 6, 2009 | 09:25 PM
daprincipal
You must have picked the wrong LEDS because the ones I just installed work and work really well. They light up a pretty nice area around the entire rear of the truck. I definitely won't go back to the stop lights. I ordered from v-leds.com
Old Nov 7, 2009 | 01:33 PM
jason2922's Avatar
jason2922
Can you post a direct link to the exact ones you bought and installed?
thx
Old Nov 7, 2009 | 06:37 PM
turk1270's Avatar
turk1270
thats where i bought mine i have the 36 hid smt ones i paid $36
Old Nov 8, 2009 | 08:41 PM
daprincipal
http://www.v-leds.com/Exterior-LED/P...26829-1-2.html
I paid less than the 59.99 posted. If you call them and tell them you heard of them from Tundrasolutions they give you 15% off. My brother drives a tundra and told me about this. Apparently the owner drives a Tundra.
