H.I.D acting up
yeh I have read up on threads where people have bought the lights from twiggy...i thought ive still seen people that are having problems with them...i really wanted some but i just dont know if they are too much hastle to full with...i dont want to install them and then they may not work properly
A relay won't take out the flicker, it's in the vehicles electrical system. It's the computerization of the electrical system - most HID systems are 35 watts, the incandescent halogen lights are 55 watts. If the computer senses that less power is being pulled, it must mean that a light is out, therefore disrupting that circuit and causing an error. The cancelers pull the 55 watts, but don't pass it on to the ballast so the system will work flawlessly.
You need cancelers to eliminate the flicker. If you want to run a relay so you're not using the truck's headlight circuit that's fine, but once again a relay won't eliminate the flicker.
well after reading all the posts i ordered the cancellers....found them on Amazon for 19.99 a set.....hopefully that does the trick....and to all those guys on the fence about HID's....I assure you if you do your research and get the correct stuff to install them.....they are a million times better than the stock headlight set up.....dont get disgruntled....i haven't yet...haha
I installed HIDs(not twiggy') with cancellers and didn't have a problem. I was having other issues with the truck, not related to the lights. The dealer replaced the TIPM module(front fusebox), on my home from the dealer my left headlight would not come on. I installed a relay and have not had an issue since, other than a little flicker on start up.
I dont know why everyone is getting flicker..
I just had a problem yesterday for the first time since I put them in the truck back in February. I hit a monster puddle at highway speeds and I cooked a ballast, luckily had a spare from my car and put that in. No problems with flicker ever, this is with quad lights. I bought some cheap cancelers off of ebay.
Got my cancellers in yesterday...19.99 off Amazon.....took about 20 minutes to dig both headlights out and install the cancellers.....turned on the truck and VIOLA! both headlights came on without any hesistation....have been working perfect even since....my question now is will I need another set of cancellers for the fogs when I getthem in?
