Trailer brake
Old Jan 9, 2010 | 10:34 AM
  #71
oldjeep's Avatar
oldjeep
Originally Posted by janet794
We installed the Tekonsha P3 in the hole where the Integrated Brake controller should be. But, the harness we have is the wrong one. So, my hubby is off tot he Dealer. Hopefully he comes home with a functioning trailer brake controller.
Thank-you for the knowledge base on this forum and the correct part number!!!!
So it's mounted with no access to the manual brake lever? Hope you don't drive on ice. That controller should be sticking out about 2" so that you can use the lever.
Old Jan 9, 2010 | 10:39 AM
  #72
oldjeep's Avatar
oldjeep
For models without the center console, this is a handy mounting place where it can both be seen and reached.
Old Jan 9, 2010 | 12:46 PM
  #73
topgun's Avatar
topgun
Who mounted it like that?
I can clearly see the pocket from my seat. I guess the factory figures most others can too. But I do agree that the lever has to be accessable. The controller really doesn't have to stick out far at all due to the angle of the pocket. I can get a good 2" exposed on the bottom with the top front being flush mounted. The G2's lever moves in a straight line vs the P3 and Prodegy which have to swing in an arc. Has a better fit also due to the shape of the box.
Old Jan 9, 2010 | 12:57 PM
  #74
oldjeep's Avatar
oldjeep
Janet794 posted that picture of how her husband mounted his. I can't see that pocket at all unless the wheel is turned - with the steering wheel and seat set the way I like it.
The P3/Prodigy manual controls have always been a little inconvienient compared to other brands, but they are the best controllers I've used (never tried a G2)
Old Jan 9, 2010 | 06:25 PM
  #75
StuartV's Avatar
StuartV
First you have to take the panel off around the steering column. There are bolts to the right and left. Once that panel is off, you will see the screws to remove the cubby. The cubby space was cut to fit the controller, put back into place and then we screwed the permanent bracket in place to hold the controller. If you look closely, there is a space on the bottom that is open to allow access to the bottom of the controller and the pulse switch.
My hubby just got home with the correct pigtail that connects to the truck. All ready to go! The next challenge is removing the cover from the camper that has over a foot of snow on it. We leave January 18th!
Good luck with your installation.
Thanks for the info!
For those that follow, the two bolts at the bottom of the dash can be removed with a Phillips head screwdriver or a 7mm socket.
That will let you get to one of the cubby screws. For the other, you just have to pull off the plastic panel on the left end of the dash. The piece this is normally covered by the door, when the door is closed. It just pulls straight out - no screws.
The 2 screws holding the cubby hole thingie in are Torx T20.
I've got mine out now. Looks like some plastic cutting will let me mount my Prodigy in that pocket without too much trouble. Good to know a replacement pocket is only $9, in case I ever need to put it back to stock.
Old Jan 10, 2010 | 12:25 AM
  #76
topgun's Avatar
topgun
The bezel is $9, not the pocket. That's why I went with the bezel.
Old Jan 10, 2010 | 11:44 AM
  #77
05Dakotaho's Avatar
05Dakotaho
Anyone have opinion on this controller?
http://i.b5z.net/i/u/1080235/f/Brake...r_Brochure.pdf
Sure looks like it would fit nicely in the OEM slot and the manual lever is on the front of the unit much like the OEM.
Old Jan 10, 2010 | 12:50 PM
  #78
oldjeep's Avatar
oldjeep
Appears to use the same sort of technology as the Prodigy/P3. Never heard of anyone using them, and there don't appear to be any reviews online but they sure are cheap.
Old Jan 10, 2010 | 01:49 PM
  #79
topgun's Avatar
topgun
Looks like it is a single axis controller as is the Prodigy and P3. The Hayes G2 is a tri axis controller, some of the Valley products dual axis. Any of them would be fine for most people though over the time activated controllers.
Just ordered a G2 for $111.10, free shipping and a direct fit harness for the 09. Got it from Southwest Wheel, used coupon code "autoforums" for an extra 5% off.
Old Jan 10, 2010 | 07:17 PM
  #80
janet794's Avatar
janet794
Default brake control
It is hard to tell in the picture, but there is enough of an opening under the P3 to move the emergency lever. We are not very tall, I am 5'2" and my hubby is 5'6", so we are not far from the pocket to reach the lever in an emergency. The controller is as visible as it needs to be. We have bucket seats, so the options for mounting were quite limited. We do travel in the winter, but not during really wintry driving conditions. We have never had to use the emergency lever, thank goodness, so far in our traveling experiences. We are leaving in a week to travel from PA to CA, so we'll let you know how the new 2010 does in it's maiden voyage. Always an adventure or two!!!
