Can you turn off mds on 09 ram.
Old Apr 23, 2010 | 02:49 AM
Phoenixguitar's Avatar
Phoenixguitar
Default AutoStick downshift to 5 works perfect
Originally Posted by jayman84
three options.
1. drive with the autostick engaged with it in 5th gear and it will run just like normal but won't let the mds turn on.
2. turn on the tow/haul mode
3. buy a programmer and you will be able to disable it.
AutoShift on 5 is all you need to do, then you are able to use 6th gear or ECO mode if truck is not being push with a need for more fuel. Eco mode is good for highway driving. May save a few bucks. I upgraded cold air and muffler seemed to help with eco mode a little, I like having control of V8 to V4. The original post is correct, there is a little vibration in the pedal, what you can expect with a V4 pulling a 5000 lb vehicle, the hemi MDS system is built to handle it. Don't sweat it, this truck is the best Ram I have owned in the last 30 years. Good Luck, stay away from changing computer etc.
Old Apr 23, 2010 | 03:54 PM
matt3's Avatar
matt3
Mine would vibrate with MDS engaged also. I complained and they gave me a flash for "MDS drivablility issues" the truck was better, not perfect but better for about a week or two. Then the vibrations came back. I disabled it with my Superchips Cortex and it is super smooth and the power is instant. I only saw about .5-1 mpg decrease and I couldn't be happier.
