LSD/Gear Change quote
Old Feb 18, 2010 | 02:17 PM
ilandaze2's Avatar
ilandaze2
Default LSD/Gear Change quote
factory style locker $395
Detroit locker $685 - dont know what kind?
$590 for 3.92 regear, oil additive and everything. Parts and labor.
Going to find out if the $590 includes the master install kit. also what kind of locker the detroit is (hopefully truetrac) and how much an auburn is? is it even worth installing the stock LSD?
Old Feb 18, 2010 | 02:22 PM
MiRamDriver's Avatar
MiRamDriver
Sounds pretty fair to me. If you are paying for the swap, I would without a doubt go with the detroit trutrac.
Old Feb 18, 2010 | 02:38 PM
TI 3VOM's Avatar
TI 3VOM
Can't go wrong with Detroit. Had one in my last truck and that thing was amazing.
Old Feb 18, 2010 | 02:48 PM
chambers's Avatar
chambers
Gears should be $200-300 (they will be more if they're mopar) and master install should be about $100, and you can get the DTT for about $525. Who is giving you the quote?
Old Feb 18, 2010 | 03:41 PM
ilandaze2's Avatar
ilandaze2
local suspension shop here in SoCal. quoting me $560 to lower with springtech but thats only a 2/3" drop. trying to go with a mcgaughy kit.
Old Feb 18, 2010 | 03:48 PM
ilandaze2's Avatar
ilandaze2
what do they have to change out when they change the gears and lockers? is the master install kit required?
Old Feb 18, 2010 | 04:54 PM
chambers's Avatar
chambers
The master install kit includes a lot of things, here is a link to one http://airram.com/product.php?catego...&productid=171. Yes you should get a master install kit when changing the ring and pinion. They are going to be pulling out your old open carrier and replacing it w/ the DTT or locker, and they will take out the old ring and pinion and then put in the new one's. What size tires are you planning on having b/c you might want to get 4.10's or 4.56's?
The most important thing when dealing w/ a new ring and pinion install is to find a shop that does them on a regular basis b/c they are not an easy job any mechanic can do. I suggest you find a local 4 wheel drive shop that does them on a regular basis. Paying a little more for parts isn't bad when you get them through the shop doing the work b/c then they can't blame anyone but themselves if it's wrong.
Old Feb 18, 2010 | 05:04 PM
oldjeep's Avatar
oldjeep
When people simply say detroit locker, they usually mean a real one "The detroit locker" A truetrac is pretty much like having no locker at all, a lot of money for nothing.
Old Feb 18, 2010 | 05:38 PM
Attono's Avatar
Attono
Truetrac is an LSD. It's a really good LSD, but an LSD nonetheless. The detroit locker is selectable, either open or completely locked.
Old Feb 18, 2010 | 05:48 PM
oldjeep's Avatar
oldjeep
A detroit locker is in no way selectable. It's an automatic dog clutch locker. The only mass produced selectable lockers around are the ARB, OX, Yukon Zip Locker and the Eaton E-locker.
A true track is only an LSD in the sense that it slips ( a whole lot). Rather than clutches it uses a hokey helical gear setup. Never met anyone who owned them who liked them - been at least 3 guys in my club who have thrown them away. If you want an LSD, then an auburn is a much better choice.
