Back Up camera questions
Old Mar 10, 2010 | 06:57 AM
daprincipal's Avatar
daprincipal
Default Back Up camera questions
http://www.dodgepartsstore.com/produ...oducts_id=3062
This is the cheapest I have found a back up camera kit for my Ram. Anyone found it cheaper anywhere. $248.17
Anyone purchased from dealer for cheaper? Who has installed one and how difficult for a less than average handy man? I did purchase the AllGig so I won't have to cut any wires. What are the advantages of having dealer install? If dealer installs will it then be covered under my warranty?
Old Mar 10, 2010 | 10:10 AM
Secret Agent Man's Avatar
Secret Agent Man
If you are going to use the AllGig, your install will be pretty easy, even for a less than handy person. I found the Mopar instructions pretty straight forward for the camera. Just make sure you wrap masking tape around the connectors on the end of the wire to keep them protected when you run it under the truck along the body harness. Its getting close to a year ago when I bought and installed mine, so I can't comment on the price intelligently, but it sounds about par. Someone might have found a better deal using ebay or something. Good luck and keep us posted want you end up doing.
Old Mar 11, 2010 | 09:02 PM
jcastr57's Avatar
jcastr57
I got mine from the dealer for $255 wholesale price. If I remember correctly, I think that site you linked to had high shipping costs. I opted to have the dealer install it along with the radio for $190 because they were going to charge $100 (1hr labor) to program it to the vehicle anyways and by letting dealer install it it becomes part of the vehicle warranty as if it came with it from factory, so that was worth the extra $90 bucks to me. I was also a little nervous about installing it myself because I have no electrical experience and the install requires splicing and soldering wires to the vehicle's brakelight wire or ecu. I also read about other people's install troubles and how long it took (one guy had the dealer install it and they had to call Chrysler tech support to get it to work) so I decided I'll tackle other tasks myself and leave this one to the dealer.
Old Mar 11, 2010 | 11:12 PM
Secret Agent Man
The guy with the bad experience at the dealer where they had to call Chrysler's tech support had a unit with crossed wires, so its not the norm. Also, if you use the Allgig to install you don't have to splice or solder wires, nor do you have to have the dealer activate the camera (the $100 labor you mentioned above). I opted to install myself and was able to use the $200 I saved to buy other goodies for the truck. To each his own though.
Old Mar 24, 2010 | 10:57 PM
laboy's Avatar
laboy
OK guys let me clear one thing. If I have factory nav installed on my 2010 truck and I want to install back up camera my self I don't have to visit dealer for camera activation?
Thanks!!
Old Mar 25, 2010 | 12:50 AM
yotaman96's Avatar
yotaman96
Thanks!!
You do unless you have the allgig or lockpic. I chose the allgig. It works great.
Old Mar 25, 2010 | 01:17 AM
laboy's Avatar
laboy
I heard stereo may stop for few sec. some times...
Where do you get allgig? And do you have OEM camera?
Thanks!!
Old Mar 25, 2010 | 01:26 AM
yotaman96's Avatar
yotaman96
Thanks!!
I believe the stereo stopping issue is with the lockpic. No problems whatsoever with my allgig. Yes, I installed the oem camera. Here's the contact info. Tell her you're a forum member.
Susanne Lazarev
susanne@nav-tv.com
Ask for Susanne for special pricing
1-866-477-3336 ext 119
Old Mar 25, 2010 | 01:34 AM
laboy's Avatar
laboy
Thanks a lot for info!!
I found this store http://navtv.com/product/9/allgig-usb-hs.html
did you paid less?
Old Mar 25, 2010 | 01:38 AM
yotaman96's Avatar
yotaman96
did you paid less?
Yes, I paid less. Call Suzanne and let her know you're a forum member. She'll cut you a deal.
