Rim and Tire Experts....
Old Mar 29, 2010 | 11:51 PM
OneSickHemiRam's Avatar
OneSickHemiRam
Default Rim and Tire Experts....
I want to run these wheels:
With these tires:
http://www.discounttiredirect.com/di...w=false&cs=305
I plan on running them in 20x9. I do not want to lift my truck. The overall diameter on this setup is 33.5" and the stockers measured 33.25. What offset will I need to get these on my truck. I have a 09 4x4 Hemi.
Thanks Jae
Old Mar 30, 2010 | 12:58 AM
CaliAthlete's Avatar
CaliAthlete
Where do you guys shop for wheels online...? I had some pretty common American Racing Torque Thrust Ms on my Camaro, easy to find at the local shop, but I want to look around more for my truck.
Old Mar 30, 2010 | 12:31 PM
OneSickHemiRam
57 views and this is the only response?
Old Mar 30, 2010 | 01:17 PM
CaliAthlete
ninjas!
Old Mar 30, 2010 | 02:31 PM
bigred3297's Avatar
bigred3297
You will be able to clear that setup with anything less than a zero offset. The more negative it is, the more it will stick out past your wheel wells but the more it pulls the wheel/tire off your control arms. I dont know exactly what positive offset would work, as you would have to ask someone who is running the same tire on a 9 wide rim what they can tuck
Old Mar 30, 2010 | 05:07 PM
OneSickHemiRam
Ok so negative offset will bring it away from the a arms. So I would have to have at least -1 to insall this setup as 0 will contact the a-arms?
Old Mar 30, 2010 | 10:49 PM
dizzyttc's Avatar
dizzyttc
I believe factory 20,s are plus 19 offset. I just put 20x8.5inch boss rims on my truck that are plus 14 offset with 275/55-20 tires and fit perfect.As someone else stated the more negative the offset the more the wheel comes out away from the truck.
Old Mar 31, 2010 | 01:38 AM
bigred3297's Avatar
bigred3297
you should clear it with a 0 but i wouldn't go positive..i believe XD has 0, -12 and -24. 0 and -12 would be optimal in my opinion
Old Mar 31, 2010 | 02:38 AM
OneSickHemiRam
Thanks.
