MOPAR MudGuards
Old Apr 1, 2010 | 03:24 PM
LongIslandRAM's Avatar
LongIslandRAM
Default MOPAR MudGuards
Anyone install the MOPAR MudGuards? Looks like some drilling is needed... Is this true? Any info would be great. Thanks Fellas
Old Apr 1, 2010 | 03:43 PM
mjaybird65's Avatar
mjaybird65
Yes, drilling is required. They do use some of the existing screws, but if I remember correctly there is one hole to drill on the fronts and two for the rears. Fronts can be done w/o removing the wheels, but unless you have a right-angle drill you may need to remove the rear wheels.
Old Apr 1, 2010 | 04:45 PM
oldjeep's Avatar
oldjeep
I've got the heavy duty mudflaps and they required some drilling. Didn't need to remove the wheels or use any special type of drill.
Old Apr 1, 2010 | 09:59 PM
superchargemyride's Avatar
superchargemyride
I have the Weathertech Mud Guards and they fit perfect. No drilling and I installed them in about 20 minutes both front and rear.
Old Apr 1, 2010 | 10:03 PM
danno5069's Avatar
danno5069
Default Mudflaps
You do need to drill one hole in each rear, an angle drill is needed if you dont want to remove the wheels.
Old Apr 1, 2010 | 10:33 PM
superchargemyride
I just put mine on Yesterday and did not have to drill the rear. They used the factory holes. They are on tight and are not going anywhere. I did not have to take off any wheels. Below is a link on what they look like and instructions.
http://www.weathertech.com/store/mvp...tChoiceIds=747
Old Apr 1, 2010 | 10:54 PM
Johnnymay15's Avatar
Johnnymay15
You are supposed to drill both the front and back for the Mopar flaps. I didn't think the back was necessary, so I didn't do it. I had to drill the front because it wouldn't sit flush without it.
Old Apr 1, 2010 | 11:33 PM
topgun's Avatar
topgun
Just be sure to use some clear body tape behind any molded flaps that go along the side of the fender or you will get paint rub through which will lead to rust. The Mopars and Husky do, not sure about the Weathertechs. It is cheap insurance.
Old Apr 2, 2010 | 12:41 AM
TI 3VOM's Avatar
TI 3VOM
I drilled both the front and back Dodge heavy duty flaps. I then painted and sealed all holes with silicone. Then put in my screws. I suppose you could get away without the extra screws, but with a flap full of mud or ice, I wanted them as secure as possible.
