Looking to buy a Travel Trailer
Old Jan 20, 2011 | 08:29 PM
  #31
Ohiododge's Avatar
Ohiododge
Default TT weight
I also have a 09 1500 crew hemi with a 3.55 rear. Mine is a 4x4 which also reduces tow rating. I pull a 28 foot keystone Hornett with 2 slides and the weight is around 8,000. I live in somewhat flat country and it gets around 6-8 mpg. It handles it but you know it's back there. I'm in the market for a 2500 CTD. My 07 hemi pulled better.
Old Jan 20, 2011 | 10:23 PM
  #32
Mirage775's Avatar
Mirage775
I've been thinking about just a small pop-up for my wife and I. I don't wanna destroy my mileage and there's no way I would even think about pulling a 28ft TT, with a half ton truck!
Old Jan 20, 2011 | 10:45 PM
  #33
smib's Avatar
smib
I pull a 25ft Passport Ultra light with one slide. it weighs 4400lbs and my 4.7 tows it okay. Anymore than that, the 5.7 would be a better choice.
Old Jan 21, 2011 | 04:59 AM
  #34
aepowell's Avatar
aepowell
Originally Posted by 09 Ram TRX 4 Lover
I have a 09 TRX 4 5.7L 3.92. I tow a 26 ft Toy Hauler, she is pretty loaded as in 3 quads and all the gear, I do not haul water or sewage tanks they are always empty. My truck pulls it fine except my only problem is mileage. I did buy air bags to help the rear end just need to install them.
What is your milage???
Old Jan 21, 2011 | 07:31 AM
  #35
hounddogg's Avatar
hounddogg
I tow a 24 foot Gulfstream ultra light fifth wheel.I got 12plus mpg pulling it a 1000 miles through Florida this past September.Full water tanks,cooler,dog and me.LOL Oh.No air bags.I have only about 2 inches of squat.In fact I wish it had a little more to level the rig out a tad more.
Old Jan 22, 2011 | 11:28 PM
  #36
krzfirefighter13's Avatar
krzfirefighter13
i pull a 32 ft keystone springdale with the bunks in the back not sure of the weight but my 09 trx4 pulls it no problem. rv dealer checked and i am well within the weight restrictions of the truck .
Old Jan 23, 2011 | 01:58 AM
  #37
72combo's Avatar
72combo
I am in with the crew that thinks the truck is under rated, I overloaded the box in my crewcab by 300 lbs and well I didn't even realize I had anything back there until I got out and saw the back end a little low but it didn't bottom out and the power was there to go, not like old 360 cid pickups that got 8 miles to the gallon but had no power but we pulled 10000 lb trailers, like I said before its a truck and I believe they can do way more than they rate them, would never admit to anyone if I pulled a trailer overweight if I did just in case something blew up but I am sure this truck could easily pull 10grand on a fairly level maybe a few long hills on maybe some higher short ones not sure until I hook one up and give it a go.
Old Jan 23, 2011 | 04:21 PM
  #38
duhameister's Avatar
duhameister
I towed a 25FT toyhauler with my 08 1500, I stopped at the scales and it was at 15,600 pounds. I live it WA state and have towed over passes fully loaded with a Polaris RZR in the back. I averaged 8 MPG, but like the other I knew it was there. I've towing over 20,000 miles with this set-up without issues. If I took it over 60 MPH the tranny would start to warm up. I ended up trading the truck in for a Ram 2500 Diesel last month. Best idea ever, that thing doesn't even have to down shift to go up the passes now.
Old Jan 24, 2011 | 11:10 AM
  #39
KDubya's Avatar
KDubya
Have any of you upgraded the brakes on your truck - or looked into it? I havent had any braking issues while towing but I'd like to know what options are out there for beefing up the stopping power.
Thanks -
KDubya
Old Jan 25, 2011 | 11:13 AM
  #40
andy78's Avatar
andy78
i tow a 2010 jayco 26ft tt dry weight 4700 lbs, loaded to about 5500 lbs. It tows it decent, gas mileage is around 8 mpg. I have the 3.55 gears with the hemi crew, tranny does alot of upshifting, even on highway, wish i had the 3.92's tho.
kdubya i never had any brake issues, but i have a brake controller which helps alot for sure..
