Power Windows ?
Old 11-08-2010 | 07:31 PM
Mark Benson's Avatar
Mark Benson
To relearn/normalize the window module, start by raising the door glass to the full-up position by pulling up on the window switch to its second detent and hold the switch until the door glass is fully closed. Continue to hold the window switch up for two seconds after the door glass is full closed.
Lower the door glass to the full-down position by pushing down (depress) the window switch to its second detent and hold the switch until the door glass is fully open. Continue to hold the window switch down for two seconds after the door glass is fully open.
Old 11-08-2010 | 08:15 PM
lil_jo_25's Avatar
lil_jo_25
SLT Crew Cab and both sides work.
Old 11-08-2010 | 10:09 PM
the2nd2lastfaul's Avatar
the2nd2lastfaul
Thanks Mark Benson !!! It worked like a champ!! Do you know what caused this to stop working in the first place? Is it just a fluke that happens on its own or is it something I mistakenly did? Is good to know that if it does happen again I can fix it quickly but if I can prevent it that would be great. Thanks again!!!!
Old 11-09-2010 | 08:27 PM
Mark Benson
yea it's pretty much just a computer glitch and the relearn procedure will take care of your problem, till it desides to glitch again which maybe highly unlikely, but ya never know
Quick Reply: Power Windows ?
