New 1500 RAM Owner here! A couple of questions!
Old May 7, 2010 | 03:36 PM
blackram09's Avatar
blackram09
The truck will let you know when it needs an oil change the instrument panel will say contact dealer oil chang due. mine usaully does it around every 5k. As far as being able to tow the breakin period is 300 miles. Your bumber should have some print on the plasic peice that will tell you how many pounds you can to with a class 4 hitch mine will tow 5000 lbs off the lot. I will be getting a class 5 which will allow to tow more.
Old May 7, 2010 | 03:39 PM
RuggedGirl's Avatar
RuggedGirl
okay so is it true you can go longer with oil changes in trucks then cars? and why is that? but if you're hauling a trailer shouldn't you change it more often (as I frequently haul a horse trailer)
Old May 7, 2010 | 03:59 PM
JB007Rules's Avatar
JB007Rules
Mine came with a Class 5 hitch and it's rated to tow 10,200 LBS
Old May 7, 2010 | 05:30 PM
RAMRAM69's Avatar
RAMRAM69
thanks guys! Illl go for a real long drive tonight! LOL oil will be change after 1000kms to synthetic for sure!
Old May 8, 2010 | 12:57 PM
John Valdes's Avatar
John Valdes
Don't worry about when to change the oil. Mine came on at 2500 miles. But I am at 9000 miles on a 2009 and only changed it twice. It's driven very sporadically.
Don't forget, 16 new plugs at 30,000. That's right, 16 new plugs at 30,000 miles and every 30,000 miles there after. My dealer quoted $359.99 for the recommended plugs and tune up. Tune UP?
They do not recommend platinum plugs either. My last truck had over 100,000 miles and the plugs were changed once, at 100,000 miles and only 8 plugs not 16.
