evic question
Old May 15, 2010 | 06:09 AM
bonza's Avatar
bonza
Originally Posted by zx14k
with the old evic it was 94 to 96 mostly 95 now it is 89 90.i have a personal obd scaner that read 94 to 96. with the old evic my delay on my automatic climate control went out at 61 with the new 56.thank
I have the same 5C degre lower problem. It started after installing the ECO flash. Reverting to an older software version solves the problem. Downgrading from P/N 05172533AI to P/N 05172533AH will fix it (you will lose the Fuel Saver light)
Old May 15, 2010 | 09:02 AM
BigBlueEdge's Avatar
BigBlueEdge
Maybe the new flash actually has a more accurate temp reading?
Rob
Old May 15, 2010 | 09:15 AM
ran jr's Avatar
ran jr
I questioned this at first but my latest drives have only given a operating temp of 194F instead of the previous 205F. The OP states his scanner shows a different temp than his EVIC does which also goes along with your claim.
But if I have to choose between the 'Fuel Saver' light, which I got a year after purchase, or a temp reading 5C below true temp, I'll take the 'Fuel Saver' light.
Old May 15, 2010 | 09:29 AM
Sobomaster's Avatar
Sobomaster
I too would prefer the light over the accurate temp. But I'd still complain to Dodge.
Old May 15, 2010 | 04:59 PM
72combo's Avatar
72combo
I bet you are probably getting the correct temp now. I was told the TSB also fixes a few other bugs....no info on the bugs and I am not gonna ask sorry.
Old May 15, 2010 | 05:46 PM
zx14k's Avatar
zx14k
[quote=ran jr;2129421]I questioned this at first but my latest drives have only given a operating temp of 194F instead of the previous 205F. The OP states his scanner shows a different temp than his EVIC does which also goes along with your claim.
But if I have to choose between the 'Fuel Saver' light, which I got a year after purchase, or a temp reading 5C below true temp, I'll take the 'Fuel Saver' light.[/quote
my mecanic said the same thing,but i will keep the ECO.the engine temp is lower but i dont know if the oil and trans temp are lower to, cant remember before.
