Operating Temps.
Old May 18, 2010 | 08:24 PM
TI 3VOM's Avatar
TI 3VOM
Default Operating Temps.
Did some towing on the weekend and was watching my temps. Problem is, without a typical guage showing the yellow/red zones, I have no idea what would be considered high temps. I would assume something would go red, or an allert would pop up if it got to warm, tranny, oil or coolant but what would be considered too high a temp?
Old May 18, 2010 | 08:30 PM
CL8N's Avatar
CL8N
There is a little bar below the temp. number and in the middle of that bar is a indicator for normal operating temps.
Old May 18, 2010 | 08:51 PM
TI 3VOM's Avatar
TI 3VOM
My issue was, if that is what the bar was for, as I got to it, poof, it is gone. Then you have no idea how far over it you are. Unless you remember where it is. And normal operating temp should be a range, not a single number. How far above that till you hit a caution zone, or a danger zone?
Old May 18, 2010 | 11:22 PM
Busta1n2's Avatar
Busta1n2
Interesting question - my truck actually shows the trans temp
Old May 19, 2010 | 01:24 AM
TI 3VOM's Avatar
TI 3VOM
So does mine, it shows the temp and where you are at in the bar below it. The bar shows -40 to 300 for trans temp with a blip in the middle at around I believe 180? I can't remember what the temp was when I hit the blip. So, above the blip, how far above is too far? Is 300 ok? I would doubt it, but like I said, it shows no warning zone, unless it does something if it gets too hot?
Old May 19, 2010 | 02:38 AM
CL8N's Avatar
CL8N
I believe how it's setup is the middle of the bar is the operating range for all the temps. but I see what you're saying for it not having like a caution zone.
