Old Aug 14, 2015, 07:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Towing & Hauling Guides
Print Wikipost
The complete story on the Trailer Brake Controller on 2010 Models.
Old Nov 17, 2010 | 12:54 PM
  #81
autoengmike's Avatar
autoengmike
Finally out according to my dealer.
I started a new thread: https://dodgeforum.com/forum/4th-gen...r-finally.html
Sorry, wrong information. Will update when finally available...
Old Feb 16, 2011 | 09:06 PM
  #82
llllll's Avatar
llllll
my 2010 ram 3500 does that too. my trailer is older, who cares. the alarm bell sounds every five seconds saying the trailer brake is disconnected then connected. its ok on smooth roads but on bumpy roads it drives me nuts. i think it's a dodge software problem i don't care if the light comes on but the bell must be stopped
Old Feb 16, 2011 | 09:18 PM
  #83
llllll's Avatar
llllll
my truck does that too, every bumb the light and bell sounds trailer brake disconnected then connected. the bell makes me crazy.
Old Feb 17, 2011 | 05:31 PM
  #84
mcclellandj's Avatar
mcclellandj
Went with the P3, and installed it just like the video below.
http://www.youtube.com/watch?v=tcUAKOZ03xg
Old Feb 26, 2011 | 08:14 PM
  #85
djf48's Avatar
djf48
Will this also work for the 2011 2500 ST? Is the part number the same for the bezal? I would like to add the factory brake control and bezal to my truck but the dealer said it wouldn't work. Thanks
Old Mar 16, 2011 | 01:13 PM
  #86
kingquadcab's Avatar
kingquadcab
Default integrated Trailer Brake Controller add on
I e-mailed CAGRIS Helpdesk Group [cagris@chrysler.com] today and this was the reply.'The Mopar kit number is 82212548 and it is currently available"
check into guys!
Old Mar 16, 2011 | 08:33 PM
  #87
Oleksakjr's Avatar
Oleksakjr
You dont need a "kit"
If you have the wiring in place, just buy the controller (part numbers is a few pages back) and the bezel and you're good to go. If you want it in the EVIC then get it flashed... pretty simple
I get a kick out of people waiting for this "kit" when you couldve just done it yourself a while ago...
Old Mar 17, 2011 | 02:29 AM
  #88
72combo's Avatar
72combo
Originally Posted by drober30
I doubt Mopar would make it work for the 09 since it would be just one model year. That's to bad, I really like the factory integration.
Well it is obvious it was planned at some point since the same little pocket is on the 09 that is on all other years after that don't have the controller. The bezel and controller fit just like in the latter years. So they should have a plan for it, but really I am hearing it is going to be an obsolete controller in a few years because of the type of brakes....I was told this by several trailer companies....no they were not just trying to sell me a controller.
Old Mar 17, 2011 | 06:35 AM
  #89
kingquadcab
well, maybe this 'kit" has everything you went out and bought seperately. And maybe, it will tell what what build dates are effected. Some people don't have the time to sit around and try and figure out what has to be done to acomplish this installation. Seems like all the other posts go back and forth on what can be done or what can't be done. after awhile it gets confussing.
Old Mar 17, 2011 | 09:18 AM
  #90
Oleksakjr's Avatar
Oleksakjr
Its pretty simple man... instead of wasting your time for a kit it couldve been done a while ago. The kit will include everything I bought seperately for what looks to be a higher price too...
All you need to do is look for two connectors behind the cubby hole, if you have them buy the controller and bezel and your done. Connect it and screw it in... you dont even need the dealer to flash the truck it will work without the flash but it just wont display the brake info on your cluster. If you want that go to a deer and have them add the option code. You will need to do this same thing with the kit anyways
I dont see whats so hard about this, the kit does not include anything else. The only bigthing is if your truck has the plugs or not, so far it has nothing to do wih build dates but more of trim. Even then some slts have them while laramies dont. Thats the only issue...
Brake type obsolete?? I was told this eight years ago as well and electric brakes havent gone anywhere the guys full of himself. There are different types of brakes but they arent goin anywhere soon, youll be fine
